396 Valve Adjustment Question - Team Camaro Tech
Camaro Tech General Tech Area
Thread Tools Display Modes
Old Dec 7th, 08, 10:50 AM
mtdubvee1 mtdubvee1 is offline
Tech Team
Default 396 Valve Adjustment Question
Okay heres the problem, I had a very loose rocker arm on my 396. So now Im going to adjust my valves. Problem is I dont know what type of CAM I have to get the specs. Is there like a "good universal" gap setting for these that I could use. Anywhere between .020 to .040 or what. Oh and will i be measruing like .020 or .002? Please help
Old Dec 7th, 08, 11:21 AM
Fred Ficarra Fred Ficarra is offline
Fred
Default Re: 396 Valve Adjustment Question
You're on track. When you don't know the spec, .020 is the way to go. Ah, one thing, are you sure you have a solid cam?
One owner 69 Camaro,(yep, bought it new)
RS SS Hugger Orange, L88, 4:10's tru-tack posi, ducted hood, Endura, spoilers.
TH400 (CX) with Coan 8" converter, GV-OD, 8 track still on console and best et 10.495, 128.79mph 1.428 60'
All with 1960's stuff. (except tires and converter)
+ MT Super Scavenger headers & 3" full exhaust with X pipe.
1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too.
http://epitomesrebuild.com/
http://ss427.net/
Old Dec 7th, 08, 11:31 AM
67CamaroRS/SS 67CamaroRS/SS is offline
Charlie
First, you need to figure out why the rocker is loose. Is that cam lobe worn, are the threads on the rocker stud worn/stripped or could the nut be bad?
Charlie Knudsen 67 Camaro RS/SS 350 TKO 600, 4.10's, AFR 195 Street Heads, Comp 270H, Rhoads Lifters, Crane Ignition, Pertronix Dizzy, Performer RPM Q-Jet, Heavily Modified Q-Jet, Hooker Comp Headers, MagnaFlow 2 1/2", 144 Decibles(Alpine CDA-7998 Head Unit, RF X7 and RF 750X Amps, MB Quart Mid's & High's, Kicker L7 12" Solo Barics)
Old Dec 7th, 08, 06:13 PM
Tech Team
What is the tall tell sign of a solid cam? how do I tell the difference? I cant see the cam because my intake is on. My nut looks fine and so do the threads.
Old Dec 7th, 08, 06:28 PM
Skeeter55's Avatar
Skeeter55 Skeeter55 is offline
Skip
............................................Thats a good question.
I NEED TO HIT THE LOTTERY
Old Dec 7th, 08, 07:30 PM
phel69 phel69 is offline
Bob
If the nut is down approximately the same number of threads as all the other nuts and the rocker is loose then you very likely have a bad cam lobe.This is assuming that the rocker stud is good.
Have someone turn the engine over and watch the loose rocker to see how much movement it has.
Bob
Garnet Red 69/SS396/TH400/355 Posi Sold
'02 triple blk Vette Vert. now
94 HD Dyna Wideglide
Old Dec 7th, 08, 07:56 PM
Unreal Unreal is offline
Gary
Pull the lifter out of the one with the loose rocker. If it has a recess with a keeper, it's a hydraulic lifter. if it's one piece, it's a solid lifter.
You may want to pull the lifter anyway to inspect for damage. When I had a valve tap, it turned out to be a wiped lobe. (lost about 1/4" of lift) The lifter was so worn, the spring was rubbing on the cam!! And I only drove about 30-35 miles after it started to tap!
If the lobe is really worn, you can see that the pushrod is moving less than the others.
Old Dec 7th, 08, 08:08 PM
tony -Di tony -Di is offline
Tony
i just went tru something simular with my 350 i had a rocker go loose i have hyd lifters but anyways pull the plugs do a compression check. and while your cranking the engine check or watch you rockers and valves move .allso measure the rocker stud hight if the stud is not pulling out of the head .you can see the the rocker shafts move and measure them the get a rought idear if the cam lobs worn but i had a bad valve seat so when i adjusted the rocker it would loosen again because the valve was being pulled thru the seat
Old Dec 8th, 08, 06:22 AM
Tech Team
Well I gapped them all at .020 last night. I started the engine and the clicking/tapping noise went to a deeper noise after i tightened the rocker.
Ill pull all the plugs and do a compression check. I plan on starting it up and looking at the valves move to see if it moves the same as the others.Let me know if you guys come up with anything else.
Old Dec 8th, 08, 07:19 AM
Charlie
It sounds like you may have a worn cam. Since you have already adjusted the valves, remove the valve cover from the side that was loose, and measure the travel of that rocker and the other rockers. They should all have the same amount of upward travel. If not, then the cam is worn and needs to be replaced. That is, provided the stud is not bad. I wouldn't just leave it like it is without inspecting it. Not to mention, you said it now has a deeper sound. I would do the inspection with the engine off and turning it by hand. It easier to watch the rockers that way, but that's just my opinion.
  #11
Old Dec 8th, 08, 08:28 AM
NHBandit's Avatar
NHBandit NHBandit is offline
Mark
no pressed in studs with a BB. I agree it's a fairly common problem with smallblocks that have stiffer than stock valve springs. Do you have access to a dial indicator with a magnetic base so you can check the cam lift against the other cylinders ? You can do that at the rocker without taking anything apart. If it's less than the others you need a cam & lifters. If it's the same look for a sunken valve.
  #12
Old Dec 8th, 08, 08:38 AM
Skeeter55's Avatar
Skip
What was it gapped at before the .020... Maybe they are hydraulics and you adjusted them incorrectly, (NOT AT ZERO LASH) so if they are hydraulics and you adjusted them with the lifters already collapsed then they are to tight and that might be the deeper noise you are hearing... Don't start it back up, pull the plugs like other have said and turn over by the crank bolt, check the lift on all rockers... Most of all what was it gapped at before you started.
  #13
Old Dec 8th, 08, 03:25 PM
82Vettrin 82Vettrin is offline
Chris
one can't go by looks anymore. I used this method back in the Spring and it got me in DEEP doo-doo because when I saw the snap-ring, I too said "hey, hydraulic cam", and adjusted the valves accordingly.
man, did I EVER have a time gettin that straightened out.
there is actually a solid lifter now with hydraulic-lookin inners, and my solid-cammed 454 happens to have 'em.
http://www.compperformancegroupstore...egory_Code=SFT
'69 SS X66 Camaro
454, TH400 & GearVendor, 12 bolt
'82 Corvette.
stock
'81 Camaro Pro Bracket car.
406, TH350, 10 bolt, NHRA #3148
  #14
Old Dec 8th, 08, 04:33 PM
Tech Team
Now the car will not even hit one time. It pulled fuel up to my small fuel filter 6 inches from the carb and no further. I dumped gas into the carb and still wont hit.It wont fire at all. I adjusted my rocker arms until there was no swivel in the rod. I did it by the method here. http://www.centuryperformance.com/ad...h-spg-149.html.
Please help Me!!!
P.S. Should I be tightening the rocker arm at the top when it comes up or at the bottom when its pressing on the spring?
  #15
Old Dec 8th, 08, 05:21 PM
Chris
if you haven't already done so, remove the coil wire or disable the engine in some manner so that it CANNOT fire !
then chill.. it's just nuts and bolts....
remove #1 plug. looking in from the radiator, it's on the rh front cyl.; from the driver seat, lh front cyl. (not demeaning you bud, but we gotta make sure, OK ?)
takes a helper, or a remote start-switch,, from this point:
hold a finger over #1 plug port, crank the engine. if you got no compression, the valves are absolutely wrong. this is what I encountered back-when I assumed I had a hydraulic cam and incorrectly adjusted my valves .
post your findings.
(some of the rest of you got~to jump in here now; I have a committment to attend)
'69 SS X66 Camaro
'82 Corvette.
stock
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Camaro Tech      Current Topic: 396 Valve Adjustment Question
Location
Location
First Name
Human Verification
