Vintage air on a Blown SBC? - Team Camaro Tech
Heating & Cooling Heating, cooling and air conditioning
Old Dec 9th, 08, 10:26 AM
SS69Cam SS69Cam is offline
Team Member
Marc
Default Vintage air on a Blown SBC?
I recently purchased a Vintage air set up for my 69 small block, but now may be able to buy a blown 406. Trouble is, I don't want to give up my AC. I have looked around and can't seem to find any articles or pictures of a blown motor with AC. Any help here guys?
Old Dec 9th, 08, 10:37 AM
SPARKY69's Avatar
SPARKY69 SPARKY69 is offline
BILL
Default Re: Vintage air on a Blown SBC?
Never had a car with a blower and air..i imagine it would be fine with some mods of course.....i would go for the power 1st and sacrifice the air if there were a choice....a blown 406 is cooler then the ac blowing cool....besides you got your daily driver thats got air(camry..honda..ect.)
Old Dec 9th, 08, 12:08 PM
Team Member
Marc
Originally Posted by SPARKY69 View Post
Never had a car with a blower and air..i imagine it would be fine with some mods of course.....i would go for the power 1st and sacrifice the air if there were a choice....a blown 406 is cooler then the ac blowing cool....besides you got your daily driver that got air(camry..honda..ect.)
No arguments there. It is definitely more cool, but I have most of it installed, and it gets pretty darn hot here in Sacramento. To top it off, the car is black on black.
Old Dec 9th, 08, 01:05 PM
prostreet69camaro's Avatar
prostreet69camaro prostreet69camaro is offline
Mike
Your biggest problem you will have is keeping the motor cool with a blower motor and A/C. If you underdrive the blower it will run cooler until you want more power. Then you can change pulleys and put out more boost.
Mike
69 Camaro Prostreet - purple w/ghost flames , 502 w/ 871 blower
http://s268.photobucket.com/home/pro...maro/allalbums
Old Dec 9th, 08, 01:28 PM
Team Member
Marc
I am mainly confused on how the belts route. I am a picture person and most of the time need to see it to really understand.
Old Dec 9th, 08, 01:54 PM
Mike
Are you going with a stock belt setup or serpentine belt setup. I have March pulleys on my big block but no A/C. The blower belt goes on the outside of the serpentine belts. Are you going to run roots style blower like a 6/71 or 8/71.
Mike
Old Dec 9th, 08, 02:13 PM
Team Member
Marc
I was hoping to go the stock belt route- if its even possible. I know that the serpentine belt can get kind of expensive. Yes, its a 6-71 blower.
Old Dec 9th, 08, 02:22 PM
Mike
It probably can be done but I think there is 3 belts which will limit your clearance for all the belts and fans / radiator. That is why I went the serpentine route. One belt. Good luck.
Mike
Old Dec 12th, 08, 11:33 AM
Blown69RS Blown69RS is offline
Russ
blown small block, with Vintage Air A/C..... no problems at all,,,, questions?, let me know....
Blown 69 RS Camaro
{Work in process - Current Photos}
383 Small Block
Dyno: 578 Horse - 595 LB/Torque
Old Dec 12th, 08, 02:01 PM
Team Member
Marc
BEAUTIFUL! Just what I needed to know. Now if I can just loosen this guy's grip a little on this 406. Thank you SO much!
Old Dec 13th, 08, 07:57 AM
tgifford5 tgifford5 is offline
Team Member
Ted
Blown69, I met you out in Swisher for their car show. Can you tell the guys what you used for a fan set up for cooling and what sort of clearance you have between pulleys and fans. Also what your engine temps. are with everything running. I see through your archives page 21 has a little description. Do you maybe have other pictures from different angles? Very nice car by the way!
Old Dec 13th, 08, 10:48 AM
Russ
Marc... to answer your question on the Vintage Air bracket - I had the same stamped steel bracket that you received. I couldn't tolerate using it, so I purchased what you see in the pictures.
Brackets for the Alternator and A/C Compressor are:
Zoops #8002 (Kit)
Summit's Page
Ted,
Yeah, I remember that day. Nice to hear from ya, it's been a few years now.
the radiator/fan setup is a BeCool kit.
BeCool #82168 (Kit)
Summit's Page
the closest clearance point I have is approximately 5/16" of an inch. I have included a couple of new pictures to show the area. Temperatures with everything running this past summer never went much over 195..,, on average they were more in the 180-185 range.
I drove it on five different 400+ mile trips, and many hours long joyrides around the town in CR this summer and never had any temperature issues at all.
It's sitting here in the garage if you want any other specific picture angles.
Russ
Blown 69 RS Camaro
383 Small Block
Old Dec 13th, 08, 11:54 AM
Mike
Russ,
How much boost does it put out with your pulley setup. It looks to be underdriven quite alot. My setup is about 1 to 1. The pulleys on my car are about the same size.
Mike
Old Dec 13th, 08, 01:12 PM
Russ
Russ,
when it was tuned on the engine dyno, it went up to 13 lbs. boost. I haven't ever really driven it very hard.... installed, I've personally only seen it up to around 7. It's 14% underdriven currently.
Blown 69 RS Camaro
383 Small Block
Old Dec 13th, 08, 02:14 PM
Mike
I was curious because I was looking at some charts. A 383 w 6-71 blower at 15% underdriven should put out 8 pounds of boost. With my 502 w 8-71 blower at 1 to 1 should put out 8 pounds of boost and that is what I have seen on my guage.
I am assuming yours is a 6-71 blower.
Mike
