| Team Camaro Tech Current Topic: LS1 with a 5 Speed TKO Tremaaaaac | ||
What do I need to make this happen . I am switching to a LS1, I currently have a 377 SBC with the Tremec
69 Rally Sport-Z/28-Orange/Wht stripes-White vinyl-Ivory Houndstooth Interior Fold down seat Early 69 ( 11/12/68) 5494xx vin 67 RS Coming Soon http://www.chitownracing.com/forums/...572a4a5071.jpg http://www.myspace.com/danny_db |
| Sponsored Links | ||
Advertisement | ||
67 RS/SS "YELR67" |
Thank for nothing
The first link on the results has your answer! http://www.classicchevy.com/product....9&dept_id=1857
67 RS/SS "YELR67" |
I don't think we are on the same page. I was looking for information on whats the same and what is different . I need to know if the depth is the same or different.
A LS1 with a automatic trans like a Turbo 350 or a 400 requires a different converter or a older style converter with spacers. Will a LS1 flywheel and clutch (26 spline) and a older bellhousing with a TKo 500 work together or will the Trans input shaft not be long enough.
Ahh, gotcha! Well, although I don't have the answers for you - now that you have some good details posted there are sure to be folks on here that will!
67 RS/SS "YELR67" |
There are a couple posts about this on pro-touring.com. I am doing the same thing with my ls2. I am using the Keisler bellhousing and pilot bearing along with their hydraulic set up. It is desinged together to be used with a standard ls flywheel clutch set up. I am useing the ls7 clutch kit from scoggin-dickey.
You will need:
A different pilot bearing. Probably a hydraulic clutch system. Expect some changes to shifter location, crossmember mounting location, and driveshaft length. |
Bell & Inspection Cover - 621 Reproduction GM bellhousing for LS series engines, engineered by Keisler with thick wall titanium-aluminum alloy construction and CNC machined in-house. 168 tooth flywheel. Note: LS engine has different mounting pattern than non-LS / conventional Chevy engines. Our bell has the correct mounting bosses for LS * Best 621 reproduction bell on the market! * we sell this as a kit with the stamped steel inspection cover, metric mounting hardware to the engine. Price $249 with inspection cover and hardware packs. Pilot Bearing - for LS engine with TKO, $39 LS Billet Flywheel - flywheel needs to be changed because balance and crank pattern is different. We have both dowel pin and non-dowel pin style. $269 Flywheel Bolts - again, unique to LS, so specify when ordering (pic shown is for non-LS) $16 Clutch Kit - our 11inch Sachs Borg&Beck diaphram gets the job with beautiful pedal effort and smooth release. We don't use the cheap china crap - only sealed release bearings. $249 kit - disk, plate, release bearing, alignment tool, spline lube You can run the factory mechanical linkage with our bellhousing. Or you can run our hydraulic clutch kit to reduce pedal effort about 25%. Car Craft Magazine did this swap with our parts. Check out our archives if you want to learn more. |
| Sponsored Links | |
Advertisement | |
