camaro ss differential - Team Camaro Tech
Thread Tools Display Modes
Old Dec 13th, 08, 10:08 PM
jimmie69 jimmie69 is offline
jimmie
Default camaro ss differential
need ring gear and yolk gear for 2001 camaro ss.or the whole differential assembly.had a problem with mine,got too hot,now sings to ya while going down the road.it's a zexel torsen with traction control.can anyone help me?have 6 speed manual trans.
Old Dec 13th, 08, 10:24 PM
pdq67 pdq67 is offline
Banned
Default Re: camaro ss differential
i haven't a clue what rearend you have, but I will say that if you have a decent engine up around or above 300hp and don't have at least a 12-bolt or a later 8.5, that whatever GM stuck under there is a grenade waiting to go off!
I love it when I find out they hold costs down by designing the drive train so the clutch slips 1st and when you do get it to hook, the sorry-as*d smaller rearend gears flat can't hold the power at hook-up!!
How far off am I guys???????????
Btw, what are they putting in the new 2010 Camaro's big engined IRS??
pdq67
Old Dec 13th, 08, 10:48 PM
jimmie
ha ha.don't really know what they will put in 2010,but what they put in mine would probably been alright,if i had not been so rough on it.i have 5.7 325 hp.had a bolt break off and mess up pan,but got hot also and started singing to me.need some help.
Old Dec 14th, 08, 01:05 AM
PowerWindows PowerWindows is offline
Jim
4th gens have a 7.5" diff stock. Any speed shop (local or internet) should be able to supply you with the proper ring and pinion as well as an install kit. Your 6 speed car will have a 3.42 gear stock.
Richmond gears seem to not whine as bad as Motive does but they cost more too.
If you don't have the tools or the knowledge to do this yourself then I'd advise you to take it to a shop. Expect it to not be inexpensive.
67 Camaro: 454/TH400/4.10 12 bolt. Lots of options: PS/PDB/PW, tilt, tach, gauges and more. K-K + 797-Z...
"Politics is the art of looking for trouble, finding it whether it exists or not, diagnosing it incorrectly and applying the wrong remedy" - Sir Ernest Benn
Old Dec 14th, 08, 11:44 AM
big gear head big gear head is offline
Freddie
4th gen Camaro rear ends are not very expensive in the salvage yards. I recommend that you replace the complete rear end instead of trying to rebuild yours. It will be much cheaper and easier to do yourself. Rplacing the ring & pinion gears requires setting the pinion depth, bearing preload and backlash to get the correct contact pattern. This is precision work that requires some special tools and lots of patients.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Transmission & Driveline      Current Topic: camaro ss differential
Location
Location
First Name
Human Verification
