Tools & Shops Shop Rat HQ
Old Dec 15th, 08, 07:34 AM
Hatman Hatman is online now
Will
Default Engine lift ??
Do I dare?
Old Dec 15th, 08, 07:37 AM
onovakind67 onovakind67 is online now
Default Re: Engine lift ??
What's the rating on the cable?
Horse sense is the thing a horse has which keeps it from betting on people.
Old Dec 15th, 08, 09:14 AM
Teal69 Teal69 is offline
Troy
Hook both ends of the cable to the engine and loop it over the lift. That will double the lifting capacity of the cable.
'69 RS/SS 350 Powerglide
Old Dec 15th, 08, 02:51 PM
SixtyAte's Avatar
SixtyAte SixtyAte is offline
Kevin
I hope you are just kidding. Get a engine lift and not take any chances.
Kev
Old Dec 15th, 08, 03:35 PM
68Holdon 68Holdon is offline
Robert
The lift can handle the weight with no problem. But I would think you would have a hard time controlling and manuvering the engine to the right angles for install. If you have the front clip off and setting it straight down on the sub frame i wouldnt worry at all. I had to unload a engine out of the back of my pick up and used my lift as you show but it barely got it high enough. If you dont have a engine hoist they are cheap enough to rent, get with a levler bar and you will be fine.
There are no problems only solutions
68 Camaro, RS/SS, ZZ502, Retrotek Fuel Injection, 4 Speed.
2010 RS/2SS Black, 6 speed trans
Old Dec 15th, 08, 04:22 PM
Will
Sorry I guess I should of said what I was doing here I just needed to get it into the back of my truck. All went well ,next stop dyno.
Old Dec 15th, 08, 04:32 PM
SixtyAte's Avatar
Kevin
Phew...
Glad that was the case..on the truck to the shop to go on the Dyno
Kev
