Old Dec 16th, 08, 05:05 PM
tilley88 tilley88 is online now
Jeff
Default QA1 coilovers
Ready to buy new coilovers for my '72 pro streeter, need to know which QA1's to get. Already have the QA1 coilover conversion for the front w/350 springs. Car is set-up on ladder bar, will have an aluminum headed sbc in it. Has economy coilovers on it now, and the coilover springs measure 12" at ride height. Top of the rear springs sit in cups welded to the frame rails and shocks run thru and bolt to that mount and the upper sheetmetal. I'm gonna put a tube between the frame rails and then add new mounts to the tube, so that will decrease the available mounting distance. Coilovers are already mounted in the lowest hole on the rearend. Would like the single adjustables like I have for the front. Hopefully the car will weigh between 3200-3400 lbs when done, as close to 50/50 front to rear as possible. Anybody know which would be the correct numbers for the QA1 package?
Old Dec 16th, 08, 08:41 PM
camaroman7d camaroman7d is offline
Royce
Default Re: QA1 coilovers
Jeff,
I would suggest you call a shop like www.cachassisworks.com and see what they recommend. All they do is chassis stuff so, they should have no problem recommending a spring/shock. They manufacture their own line of spring and shock (Varishock) that is VERY good (many argue they are better than QA1's). I have both QA1's (front) and Varishocks (rear). I will be running Varishocks all the way around on my other car (already have the fronts). Even if you want to stick with QA1's give them a call and see what they recommend as far as rates go. You will need to know what length you want/need though and this of course if dependent on your mounts and desired ride height.
Royce (NO XQSSS) Bradley
Pictures
Sound Clip
(brief sound clip, 3" exhaust through Borla Sportsman mufflers)
"If you are not part of the solution, then you are part of the problem" Me
Old Dec 16th, 08, 09:41 PM
Jeff
Thanks for the tip....I did realize after posting that I'll need to have my mounting heights figured out before ordering. I think I'll wait on the coilovers til I get that done.
Old Dec 17th, 08, 06:04 AM
rtj rtj is offline
I'll crawl under the car this weekend and let you know what they installed on my car. It's packed behind tool boxes right now. Our cars should be about the same weigth, so it might be usefull info.
Old Dec 17th, 08, 11:44 AM
Jeff
Thanks!!!
Old Dec 23rd, 08, 06:38 PM
rtj rtj is offline
They are HAL shocks from QA1. One of the coil over springs has a metal band with the number "2" stamped onto it. There is no sign of a model number, but each has a unique serial number.
The previous owner said they were fairly new, so it's one less item to purchase!
Old Dec 23rd, 08, 08:31 PM
Jeff
Sweet! I bet that number 2 is for 200, as in the rate. I was kinda leanin that way. Thanks, bro! BTW, I did some research on that rack and pinion set-up of yours, the mount with A R T on it came from Applied Racing Technologies. Could you do me a little favor? I need a measurement on that rack-inner pivot point to inner pivot point if possible. I checked out the Strange unit and it shows 24.5 inches, which would really screw up bumpsteer. But I guess that ain't that critical on a part time cruiser like mine will be.........
Old Dec 23rd, 08, 08:55 PM
rtj rtj is offline
Okay, it looks to be 24 or 25 inches. It's hard to tell exactly where the pivot is with the boots on, and I've got no previous experiance with these units. Willwood makes a unit too. They show a nice blueprint with dimensions on their web page.
I'm not too worried about bump steer, this will only be a cruiser and occasionally run down the track. The previousl owner said he had to have the rack.
I just sent back a set of 2 1/8" Hooker Super Comps and ordered the 2". There was no way the 2 1/8" headers would fit, and I'd already got them when I saw guys on other forums complaining about them not fitting. Just a warning in case you planned on the 2 1/8" super comps.
Hey Tilley, you raced a lot, who makes a good adjustable front swaybar? I can't use a factory bar, as the front bolt holes are covered by the added crossmember. I'll need something shorter.
Old Dec 24th, 08, 06:21 AM
Jeff
Did'nt use swaybars on my dirt cars, but I can help you research that. I'll probably put one on my car, too.
Old Dec 24th, 08, 07:10 AM
Jeff
Try these guys.....http://www.1speedway.com/Swaybars.htm
Old Dec 24th, 08, 12:20 PM
rtj rtj is offline
Originally Posted by tilley88 View Post
Okay, looks good. Thanks.
