1970 Camaro SS 396 - Team Camaro Tech
What's it worth? & ebay discussions
Thread Tools Display Modes
Old Dec 20th, 08, 04:36 PM
TBONE1969 TBONE1969 is offline
Tech Team
Default 1970 Camaro SS 396
Hey guys i need some help.I am going to look at a 70 ss 396 car on sunday.How can i tell if it is a true ss big block.I know that it should have a Z27 on the trim tag.What is the difference between a small block ss or big block ss? It is a 4 speed and has 12 bolt rear.Thanks for any help.
Old Dec 20th, 08, 07:57 PM
Tech Team
Default Re: 1970 Camaro SS 396
If its was a 69Z i would get more responses.Are there no 2nd generation guys on this forum? Should i post this somewhere else on this website? Thanks
Old Dec 20th, 08, 08:38 PM
al8apexer al8apexer is offline
ok, here you go
www.nastyz28.com is THE 2nd gen site
a lot of us do both
that aside, the 70 SS 396 had the black rear panel, same as 67-69
it also had:
rear sway bar with welded upper sway bar mounts
12 bolt (duh!)
dual exhaust hangers both sides
different redline on tach
4 speed or turbo 400 if an automatic
unique radiator shroud
f70 14 tires on 14 x 7 rally wheels (square holes) OR RPO wheel covers
it will NOT say Z27 on a 70 trim tag (Norwood ONLY, Van Nuys tags are useless), it will have the engine code L34 or L78 IF a bb
good 70 info here:
http://www.nastyz28.com/camaro/camaro70.php
Old Dec 21st, 08, 05:12 AM
Tech Team
Thanks Jim i will let you know what i find today.
Old Dec 27th, 08, 12:45 PM
Tech Team
Ok guys i finally got to see the car.The good news is that it says L78 on the trim tag.But the body needs all new panels.Floors are solid and the trunk pan.It is complete running and driving car but not numbers matching.Looks like the original M21 trans and 12 bolt.It has 150 speedo and 7000 tach.He is asking $7,400.00 which i thought was to high.Also needs some rear frame rail repair.Paint code is 43B.So what is it worth?????
Old Dec 27th, 08, 03:37 PM
rich pern rich pern is offline
Banned
Rich
WHAT!!!!!
L78's are RARE, around 600 made, and not many found. As long as the tag is real, and I would have that verified, $7400.00 is well worth it if it can be saved. That would be a great price for a running driving 70 L78 needing panel replacement.
Rich
Old Dec 27th, 08, 03:38 PM
Banned
Rich
I bet you get everyone's attention now!
Old Dec 27th, 08, 04:04 PM
Jeff H Jeff H is offline
Yeah, as long as the tag is original you might want to grab that car right away and worry about what to do with it later. There have been a couple of 70 L78 motors or blocks up for sale lately so put a correct motor in it and it's value goes up even faster. Did it have the COX coded 3.55 posi rear or the 4.10 rear? Those 1970 original 12 bolt rears are worth some decent money too.
Jeff H
69 Z28 Hugger Orange original factory JL8 brakes, cross-ram & GM fiberglass hood - being restored
09 Z71 daily beater
Old Dec 27th, 08, 04:29 PM
CamarosRus CamarosRus is offline
Chuck
Always interesting to find another 70 L-78.
Guys, lets deal with a little REALITY.......Car sounds like it needs major expensive body work and everything else that is associated with a restoration.
Then buy ALL the necessary parts to put together a non original motor........
What are you spending????? A TON !!!!!!!
What is it worth ????????????
Open mind before wallet!!!!!!
Chuck Sharin
Seattle area
69 COPO recreation (Day 2)
70 Z-28
70 L-78
70 SS R/S
73 RS LT
Old Dec 27th, 08, 04:33 PM
Tech Team
I am with you CamarosRus.I offered $5,000.I just ran the code for the engine that is in it.Comes back as 72 chevelle 402/240 Hp.I will let you know what happens.
  #11
Old Dec 27th, 08, 08:17 PM
But you could still part it out or sell it on Ebay for probably $10K or more even if you decide not to restore it back to 100% stock yourself. Did you get the trim tag information and VIN written down so if you don't buy it, the data can still be added to the 70 L78 registry?
Jeff H
09 Z71 daily beater
  #12
Old Dec 27th, 08, 11:03 PM
DarrenX33 DarrenX33 is offline
What part of the country are you in? Depending on where your at you might be able to get a knowledgable person to look at it with you to see how much of the real parts are there. That is if your interested in doing so.
-Darren
  #13
Old Dec 28th, 08, 08:59 AM
TomBo TomBo is offline
If its in the NE part of the country I may be able to help you....
  #14
Old Dec 28th, 08, 03:33 PM
toybldr toybldr is offline
It would be a shame to part it out but its going to take some serious cash to restore it.
Jeff, for your asking price, I can't believe your car has not found a new owner yet.
Happy Holidays
to be announced
  #15
Old Dec 28th, 08, 04:16 PM
Banned
Rich
Same here Jeff. I wonder if it would be worth repainting it the correct color?
Rich
Team Camaro Tech > All Generations > What's it worth?      Current Topic: 1970 Camaro SS 396
Location
Location
First Name
Human Verification
