anyone usin shorty plug with pro topline heads - Team Camaro Tech
Thread Tools Display Modes
Old Apr 24th, 03, 12:35 PM
richard scott richard scott is offline
Post
I am having some issues with plug clearance on my 383 ci ,s10. I have the pro topline angle plug heads and sanderson shorties with 1 3/4 primaries.I didn't see an accel plug listing that fit the toplines requirement,s. the suggested plugs do go in ,but no room for a plug boot! I thought about using an old header flange as a spacer if I can't find a short plug to use
Old Apr 24th, 03, 07:42 PM
68rs406 68rs406 is offline
Sean
Post
i'm using ngk v power plugs, they are about as short as the accel plugs everybody uses. i'm running 1 3/4 long tube hooker super comps, w/ pro action angle plug heads, and they work great. one suggestion though, the plug they reccomend is a very cold heat range, so unless your compression is up there, i.e. 12:1 plus, or are running nitrous, you'll do better with a slightly hotter plug. the plug requirements are really just a 3/4 reach, washer seat plug, pretty common really. just take the number they reccomend to a spark plug website, such as ngk, and start cross referencing. also, for reference, i'm currently running an ngk # R5671A-7 in my 11.6:1 406, w/ the 220 cc pro heads. hope that helps
Sean
1968 rs, with an old school, antiquated "junkyard, never even had the valve covers off" 354" SB2.2 pump gas motor........
"I aint never seen talking win me nothin'" -Marshawn Lynch
Old Apr 24th, 03, 08:22 PM
z/27 camaro z/27 camaro is offline
Mike
Post
68rs406
im useing the same headers as you and GM z/28 2.02 angle plug heads [1970 over the counter heads] and have a clearence problem with the spark plug boot on no.3 cylinder big time. i have to use high temp socks on 3 other wires too because of clearance problems. i use the accel shortys also but your right the NGK V power are ALMOST as short.
richards problem could be the wrong headers......i found out after that there is certain types of headers that fit angle plug headers better.......headman i think???
69 Camaro RS/SS 350.<br />GM 2.02 angle plug heads.<br />223 dur/480 lift hyd cam.<br />69 z/28 alum high rise.<br />69 z/28 780 vac sec holly carb.<br />4 bolt mains,steel crank,forged flat top pistons.<br />Turbo 350 2800 stall with shift kit.<br />3:73 12 bolt posi.<br />functional ZL2 cowl induction hood<br />gear vender O.D.<br />13.2 in the 1/4 with slicks and open headers
Old Apr 24th, 03, 08:30 PM
Sean
Post
good point, z27. that thought had crossed my mind.(apparently it was just passing through ) my #3 plug is also close. its real tough to get started with a socket, had to make a "custom" plug socket for it. once in and tight, clearance is close but no burning issues at all. the rest are fine as far as clearance. it very well could be a header issue.
Sean
Old Apr 24th, 03, 08:38 PM
Post
Thanks, I dont have many options for headers,This is aS10 pick-up,I will check out the ngk plugs ,I know that they are good quality.
Old Apr 24th, 03, 08:44 PM
Sean
Post
hey, good luck. after looking back at your post, i see you say the reccomended plugs (champion c57 i believe?) did fit, but leave no room for plug boots, i would bet the shorty type plugs will take care of the problem. i'm pretty sure i would have a problem at #3 if i used a standard length plug. hope you find success
Sean
Team Camaro Tech > All Generations > Performance      Current Topic: anyone usin shorty plug with pro topline heads
Location
Location
First Name
Human Verification
