| Team Camaro Tech Current Topic: Radiator problems help me out | ||
| Heating & Cooling Heating, cooling and air conditioning |
i got probelsm with my radiator heres the probelm
the car got up to about 200 degrees thats way to high n there was heat blowin out of the vents now...the antifreeze was cold *** hell something not right about that my mechanic opened the radiator car n there was a fog coming from the radiator n that 2 was cold..im thinking i should give it a radiator flush i also replaced the themrostat. |
| Sponsored Links | ||
Advertisement | ||
Well it sounds like a stuck thermostat, even new T-stats are problems when new. Take the T-stat back out and put in a pot of water start to boil the water with a meet thermostat in to check when the T-stat opens. A good flush also is a plus.
I NEED TO HIT THE LOTTERY |
ok so i just boil water the theremostat is made for 180 degrees o i just put it n the boilin water? also my fan is not spinning...
......If I have followed some of your other posts correctly relating to this problem then the car is a late model Camaro...correct?...if so.....the problem with the fan could be a fuse or a relay gone bad.
"All I need is a fast machine". Steve McQueen My Machine: 1969 Pro Street Camaro ![]() 468 CID 661 Horsepower Turbo 40033"x19.50" Mickey Thompsons Check Out My Camaro 661 Horsepower 468 |
X2........... If it is a late model Camaro and your fan is not spinning, then check the above.... But if its an early model Camaro then check the thermal clutch fan..... Give us an update.
yea, some idea of exactly what car you're working on would be good.
JimM's firstgens.com Camaro Board Jimragtop.com New website for my vert is coming together. Do ya like the slide show on the home page? |
my fuses are fine also its a 98 camaro
Did you bleed the cooling system after replacing the thermostat? This is MANDATORY on 4th gen Camaros.
Beat it to Fit, Paint it to Match! |
no i didnt i dont want to start the car cuz of the misfire problem
Im not sure where the sensor is to bring the fan on but is it possible its in an area where the coolant is still cold? It wont come on till it gets up to temperature.
#11
thanks for all your help but im going to just have the car towed to the shop...n let them fix everything
#12
Wow. Sad. Can I suggest joining a car club or something. True, the learning curve is long but you have to start somewhere, IF you wanna be a car guy.
One owner 69 Camaro,(yep, bought it new )RS SS Hugger Orange, L88, 4:10's spool, ducted hood, Endura, spoilers. TH400 (CX) GV OD, 8 track still on console and best et 10.862, 124.24mph 1.478 60' All with 1960's stuff. (except tires and converter) + MT Super Scavenger headers. 1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too. ![]() http://epitomesrebuild.com/ |
#13
Sounds like you made a wise choice. Many "car guys" will do more damage than good working on something they know nothing about. Asking questions on a forum is fine, but you will get too many answers with different guesses about your problem, and many could be right, but without hands on diagnosis that's all they are is guesses. And don't let someone try to belittle you because you chose to go to a professional shop, it is fine to admit you don't know and aren't capable of the repair. And yes, you CAN still be a "car guy" and not know everything about cars.
#14
But Tom! It means we failed!
| Sponsored Links | |
Advertisement | |
