At what point do you quit on a restoral? - Team Camaro Tech
Body Shop Paint & Body Forum
Old Dec 29th, 08, 08:37 AM
shoe shoe is offline
Jeff
Default At what point do you quit on a restoral?
Not that I am serious about it...yet, but after a complete floor and trunk replacement I just found yet another problem area. While trying to clean up some welds from the 1 piece floor pan job, I spent a little time under the firewall yesterday, only to find more rust that likely will push me into a complete toe board and firewall area replacement. I found more crap under the cowl vent panel that looks like duct tape and fiberglass, covered with spray paint of course. I live in fear of what the sand blasting will uncover for the rest of the body.
Anyway, I feel like I have invested too much into this 67 convertible already, and with the regular body work not even started yet, the costs could easily climb into the $35k range to finish it right. However, at this rate the car could be nearly 70% replacement parts. Starting to think it's time time to cut my losses at 20k, and just write this one off to "do a better inspection next time" and move on. It is a true RS/SS 'vert, but in today's market I might not even break even when it's done.
-Jeff
Current Projects - See my albums
68 Coupe Restomod (7-2010 to ???)
67 RS/SS Convertible project (8-2007 to ???)
Old
67 SS 396 Coupe (sold 7-12), 68 SS 350 (sold 2-12), 68 383 stroker (sold 10-09), 68 SS 350 TPI (sold 2006), 69 SS 350 (sold 1987), 68 327 (1980 Bench seat column shift), 89 RS (son totaled), 88 IROC (son totaled), 76 LT1 (roommate wrecked)
Old Dec 29th, 08, 09:04 AM
deerhunter deerhunter is offline
Default Re: At what point do you quit on a restoral?
I would say it depends on what you want for the end to be. Some do just enough to get by while some are doing tons of work. I am not real sure you can ever get all of your money back on some projects. I have a lot of money into mine and might be able to come close to breaking even IF I would ever sell it.
Old Dec 29th, 08, 09:06 AM
BrewHog55 BrewHog55 is offline
Don
Jeff,
Of course each case is different, but I bought my 68 plane jane coupe for a driver and ended up with the car totally apart after a month.
My case was similar, in that there was a lot of hidden things I didn't see when I bought it.
I decided that I would do a total restoration and do it my way. My costs when done were in the 40K range. I will never get a full return on what I put into it.
It took me 4 years almost to the day to finish it up.
I had a blast doing it, there were lots of times when I either didn’t have the money to keep it going or was getting tired of it.
This car is being driven and I planned it that way.
My suggestion is that you take a break on some of the big projects and do a few of the smaller ones. The key to success is to do a little something every time you get a chance.
Don’t give up, an SS/RS Vert is worth it.
Don
Old Dec 29th, 08, 09:43 AM
Zulu28 Zulu28 is offline
Stephen
When to give up?...... NEVER!!!!!!
How bad is too bad?... Well, that one is entirely up to you...
See the following threads:
Arai's-- http://www.camaros.net/forums/showthread.php?t=126949
6781Camaro's-- http://www.camaros.net/forums/showthread.php?t=146455
cheby2's-- http://www.camaros.net/forums/showthread.php?t=121480
Mine-- http://www.camaros.net/forums/showthread.php?t=140253
and lastly 67speedfreak's thread (this one give's me hope that anything can be saved)--http://www.camaros.net/forums/showthread.php?t=136893
I guess it boils down to how much you want to do and how much you want to spend... if it doesn't work out, I am sure you can off load it to someone here on the forum...
"Schmidy"
I'm not sayin', I'm just sayin'
68 Camaro Pro-tour Project,
93 Wrangler w/ '07 5.3L (It's stupid fast)
11 Toyota Tundra Double Cab Off Road
08 CBR1000RR - The FAST bike
08 VTX1800F - The BIG bike
Old Dec 29th, 08, 09:46 AM
Stephen
btw Brewhog, that is a sweet looking ride you have there!
"Schmidy"
Old Dec 29th, 08, 09:49 AM
6781camaro's Avatar
6781camaro 6781camaro is offline
Todd
My opinion is that you first have to know what you will be happy with in the end. Do you just want a clean nice-looking driver? Do you want a 100-pt show mobile? or do you want a custom ride optioned out to the max? Etc....
Maybe step back for a while, do some reading on here of other's experiences, woes, complaints, rewards,etc... and come up with an end goal for your car.
Consider budget, space, time, family tolerance for your absences, etc...
hope this helps... I am in neck deep and then some on mine... Lovin' every minute of it.
Here's what it used to look like (running and driving when I first bought it)
and here it is now....and it will only get uglier for a little while before getting any prettier...
'69 Frost Green V8 Coupe-Building now!
'68 Sequoia Green V8 Coupe--Building now!(too)
'68 6 cyl Coupe, '75 LT350, '79 Berlinetta V6, '79 Z/28, '80 Z28, '81 Z/28, '82 Berlinetta V8,'84 T-top V6, '89 RS V8, +finally a '92 Z/28 T-top in Purple Haze Metallic--...ALL SOLD
Helpful build pics+tips from my restoration:
http://s299.photobucket.com/albums/m...ro%20%20SS350/
My build thread:
Old Dec 29th, 08, 10:43 AM
Steptoe Steptoe is online now
Steps
A resto is about hobby...forget about those TV build progs...
I btought mine 30 yrs ago, in that time after full rebuild and several body builds...and driving daily, I have put nearly $NZ100,000 into it.
The intial build cost me $18000 back in '84.
I would get between $50000 and $65000 now
That sounds like a loss...No
The 'loss' is about $50000 Or $1650 per yr
If I had been driving a japper or a modern car over the last 30 yrs, I would have lost far more than that in the 3 or 4 replacements, and that doesnt include maint etc.
Cost any resto over a short period and means big loss, over long periods huge gains
Old Dec 29th, 08, 12:08 PM
jcapps jcapps is offline
Joe
I have never given up on a project. If you are building a car to finish rather than buying a done car it will always cost you more.
But it will be done right ( depending on who is doing it) and it will be done to your specs.
I like to build because I know every inch of that car. No crap has been covered up.
I bought this car in primer "ready for paint" riiiiight
Stripped it and blasted it and glad I did. It needs a lot but at least I know it will be done right
Old Dec 29th, 08, 12:34 PM
HOGDADDY HOGDADDY is offline
mike
When they have to pry the air chiesel out of my cold dead hands.
1967 convertible T-1
Old Dec 29th, 08, 01:04 PM
vjp819's Avatar
vjp819 vjp819 is offline
V.J.
Jeff, don't let the total project overwhelm you. I've run into a lot of the same problems on a 68 that I purchased over 25 yrs ago. I drove the thing 6 years never knowing that several major problems existed. The deeper you get into it the more you'll find. I'm sure you've experienced that already. Just take it a step at a time. When I run into a costly problem that I don't presently have funds to fix, I just move back to areas that I already have parts for and work on that. It helps you feel some accomplishment and keeps you motivated to continue rather then finding a problem and hitting a brick wall until you can work on it. Sure it stays in back of your mind, but going through this myself I'm sure you have parts that you've already purchased ahead of time that you can replace and feel some accomplishment while the major problems wait. Good luck
Old Dec 29th, 08, 03:29 PM
Camaros-n-Chevelles's Avatar
Camaros-n-Chevelles Camaros-n-Chevelles is offline
Your Camaro is definitely restorable. Never Give Up! Unfortunately it is never done overnight. Check out this thread:
http://www.camaros.net/forums/showthread.php?t=128478
Tory
1968 Camaro Coupe
1964 Malibu SS Unrestored 36,000 Mile Survivor
1964 Malibu SS Hardtop
1966 Chevelle SS 396
1968 Chevelle L-79, 1 of 4082 - SOLD
1955 Chevrolet Bel Air Unrestored 15,000 Mile Survivor
1955 Chevrolet Nomad
1984 Hurst Olds with Factory Sunroof, 1 of 99
Old Dec 29th, 08, 03:44 PM
captcanuck68 captcanuck68 is offline
Ted
Jeff...what motor does it have? Is it heavily optioned, ie. power top/sports wheel/am/fm/trans/deluxe interior, etc.? What's the mileage on the od? How many owners before you? Main ques...after considering all the above...how's it gonna cut in to your life style to continue?
capt
Old Dec 29th, 08, 03:57 PM
Arai Arai is offline
Chris
AMEN! Don't give up....
Chris
-69 Camaro- X11
http://www.my69camaro.net
Follow my build here:
Old Dec 29th, 08, 04:38 PM
bighaas79 bighaas79 is offline
This is just an opinion so take it as you will but as far as I'm concerned a true car guy doesn't worry if you are going to break even or make a profit if you sell it, they build what they truly want, how they wanna build it. If your in it to make a profit your doing it for the wrong reason and you will probably never be happy with it if you short cut it worrying about the profit line. On that note however how much you have to spend, is what you have to spend, don't lose the house just to finish the ride. I only do what I can afford, but on the other hand, I don't have nearly that much in my cars, cause I do almost everything myself. So if you are paying for labor i can understand that the bill racks up quick. In the end you are the only one who can make the decision if it's the way you truly want to go.
NEVER argue with a stupid person. They bring you down to their level, and then beat you with experience.
Old Dec 29th, 08, 04:51 PM
VERY GOOD, HOG!!! I really like this answer!
I just noticed this after posting-my 1000th post! Couldn't have been used in a better place.
