vertical quarter window trim rubber installation... - Team Camaro Tech
Thread Tools Display Modes
Old Jan 1st, 09, 08:07 AM
68_RS 68_RS is offline
Default vertical quarter window trim rubber installation...
Do I need to remove window to install these?
There's a screw on bottom, right?
thanks...
Old Jan 1st, 09, 08:19 AM
Z06vette Z06vette is offline
Scott
Default Re: vertical quarter window trim rubber installation...
Yes, small screw on the bottom. Dont have to remove the window, be careful how hard yo pull on it to remove/install the seal. I broke the nylon roller trying to remove the old one & had to remove the window to fix it. I'd use some wd-40 or similar on the old one. Soapy water worked well for me to install the new one.
Scott
69 RS LS3/T56
68 Firebird vert LS1/4L60E
67 RS LS2/T56
Old Jan 1st, 09, 10:22 AM
Lucky68's Avatar
Lucky68 Lucky68 is offline
Mike
The screw keeps the seal in place on the chrome trim. You may need to use a heat gun to loosen up the seal on the quarter window. Like Scott said, there's no need to remove the window, just be careful
1968 Camaro Coupe: Forged 383, AFR heads, Edelbrock Air-Gap intake, Holley 750 dp, Dynatech headers (557 HP/543 TQ), TKO-600, 12 Bolt 3.73, Vintage Air.
http://rides.webshots.com/album/250023748XWhfQW
Old Jan 1st, 09, 09:55 PM
cool. but how do i get at the screw? remove u-jamb seals?
Old Jan 3rd, 09, 05:51 AM
Lucky68's Avatar
Mike
Once you've removed the vertical trim piece from the window just take out the screw and slide the seal out from the trim. Be prepared, the seals can be a bear to remove and install. I used WD-40 to reinstall the seals.
Old Jan 3rd, 09, 06:29 AM
DOUG G DOUG G is offline
Yes, remove the u-jam seal, then the screw on the bottom of the window seal. Mine were rusted pretty good and had to spray with penetrating oil to remove and again after cleaning with some scotch brite for lube on install.
68 Camaro~LSx
Best to Date....and tuning
1.546 60'
7.132 @ 94.43 660'
11.327 @ 116.79.
RedЯum <-Pics
https://youtu.be/Of8WVNYhR1g <~More here
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Interiors      Current Topic: vertical quarter window trim rubber installation...
Location
Location
First Name
Human Verification
