| Team Camaro Tech Current Topic: Torque Wrench | ||
| Tools & Shops Shop Rat HQ |
Does anyone know what the best all around torque wrench is and the size and type; i.e. 1/4", 1/2" or 3/4", click type, etc? Thanks.
Well... I have 3. Got a 1/2 Craftsman beam type almost as old as I am. Still works perfect. Still 100% accurate. Still can be bought new for just a few dollars.
Got a click type snapon, also 1/2" drive. I "inherited" it several years ago, and have only started using it for the last year. Was hard to build up some trust, but I really like it now, particularly since I need my reading glasses to see the scale on the beam wrench. Scale is accurate to a pound, lock it and repeat. click click. The most recent purchase happened when I had to do an intake manifold on a 3.1 V6. New engine use lots of TINY fasteners, long skinny things that get torqued to loke 12, or 16 inch pounds. So this one is a 3/8" drive inch pound wrench.
68 SS (clone) Vert, #'s matching 383, TKO500, Holley EFI 04 Silverado SS The Black Beast 93 Polo Green Corvette http://www.Jimragtop.com Jim's NEW Blog! Jim Cam |
I think it comes down to how much you want to spend? Do you want a click or a digital?
"Yes im 22 years old, no i dont own an import, and yes i own a Camaro and im damn proud of it!" 68 owner-The only way to go ![]() Camaro: A small vicious animal that eats mustangs. |
I have 3. A Craftsman beam type 1/4" drive in inch pounds for doing rolling tourque, etc when setting up rear ends, a Snap On 3/8 drive that goes from 5 ft lbs up to 60 I believe, and a 1/2 drive Snap On that goes from 25 ft lbs up to 200. Both of the Snap Ons are click type. In the past when I worked on heavy equipment I had a couple that were hydraulic and MUCH bigger. Had to use a 4-1 tourque multiplier on some stuff. For example the tourque on some of the nuts on the bigger hydraulic cylnders was 4000 ft lbs... If you're going to do much automotive stuff you'll need at least a couple different ones. A small one for the inch pound stuff like Jim mentioned and a larger ft lb version for headbolts, main bearing caps, etc.
Thanks everyone, I think I have the general idea what I need now, it seems I'll need at least two, one for inch-pounds and the other for foot-pounds. Just got to decide whether click type or digital. I'm leaning towards click since I a novice, just working on my car only and I am not a mechanic. Thanks again for all your help, great site.
if your gonna buy one.... buy a snap-on...all others suck!!!
I have several but recently bought a Snap On click type and was amazed at how smooth to adjust etc it is. Very nice piece.
Torque wrenches is probably one area I wouldn't skimp on, get a good one they are much more accurate than the cheaper ones (like Harbor freight). Again Snap-on makes a very high quality Torque Wrench. Most of my tools are from Sears except my torque wrenches which are all from Snap-On.
As far as 1/4, 3/8 or 1/2 drive, that doesn't matter so much but torque wrenches usually have a range and are usually more accurate in the middle of their range. You probably will need 2-3 torque wrenches to cover a reasonable range of torque values. |
Always return your setting back to 0 when done for the day.
I bought a nice S&K click type..very pleased...1/2 inch drive...works great for heads and intakes.....
#11
I don't ever turn it back to "0" as when they are shipped they are packaged with a slight load on the spring. My Snap On came with 40 lbs on the dial when I received it 15 years ago and I still unload it to this setting. From what I have been told, unloading it completely is worse than having it cranked to the max and storing. Just food for thought!
#12
I also have a 1/2" Proto and a Mac and a flex Head Snap On 3/8 drive as well as a 1/4" drive Snap On and a inch pound Torque Guage for doing diff work and while they are OK I still use the Snap On more Frequently. JMO.
1994 Lumina Z34, 2655lbs. 446" Rocket Small Block, Brodix Canted Valve, Sheet metal intake, lenco 5 speed, 8.21/167 Best. GM Canada Documented Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973. Last edited by rszmjt; Jan 6th, 09 at 02:27 PM. |
#13
A little off the topic, BUT, I have a 35 year old Craftsman and was wondering the best way to have it checked for accuracy. It is the type that you set the torque and it "clicks" when it reaches that point.
Any suggestions (other than throwing it away )
Don '62 Corvette '65 HIPO Mustang Convertible '79 Toyota Landcruiser '69 Z28 (Girlfriend's) |
#14
Anyway any Snap on or other tool dealer has the ability to test torque wrenches, or you can do it youself . If a buddy has a known Good Torque Wrench you simply put them opposite each other with male/female torx sockets and check which one clicks first at a determined torque setting. Hope this helps. Mike.
1994 Lumina Z34, 2655lbs. 446" Rocket Small Block, Brodix Canted Valve, Sheet metal intake, lenco 5 speed, 8.21/167 Best. GM Canada Documented Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973. |
#15
I am a calibration technician for the US Navy and I can tell you for sure that you should always return them to 0 when finished using them. Also if you drop a torque wrench regardless of brand, you should have it checked. I can't tell you how many torque wrenches I've had come into my shop that were dropped, and the calibration was thrown off. We mostly use SNAP-ON in aviation, and even those lose their accuracy if mistreated. I've even seen some that were brand new and slightly out of specs. If I wasn't up here in Great Lakes pushing boots right now I would say you could send me your wrenches and I would calibrate them for you, but you will have to wait about another 3 years for some free cal services.
