Z/28 291 heads - Team Camaro Tech
Old Jan 11th, 09, 12:26 PM
Toddscar19 Toddscar19 is offline
Todd
Default Z/28 291 heads
Does anyone know if 1968 "291" Z/28 cylinder heads come with pressed in studs or screw in studs w/guide plates. Also, is the cylinder head chamber shrowded on the intake valve side. I've seen this on the LT1 replacement heads. I'd appreciate the info, thanks, Todd.
Old Jan 11th, 09, 01:12 PM
rszmjt rszmjt is offline
Mike
Default Re: Z/28 291 heads
Todd, Original 1968 "291" heads come with pressed studs, screw in studs and guideplates where not factory installed until 70.
Also original 2.02 heads are machined around the Intake Valve area, if they are not machined then they are converted 1.94,s
1994 Lumina Z34, 2655lbs. 446" Small Block, Brodix Canted Valve, lenco 5 speed, 8.21/167 Best. New Bickle Cavalier, 1810lbs for 2010. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973.
Old Jan 11th, 09, 01:34 PM
Todd
Thank you
Old Jan 11th, 09, 01:36 PM
Mike
Your Welcome.
Old Jan 11th, 09, 03:31 PM
69z28freak's Avatar
69z28freak 69z28freak is offline
Mike
Hey RSZ I have a head question. What are the correct head numbers for 69 and 70 Z 28 heads? Are they the same heads with guide plates on the 70? Thanks
Old Jan 11th, 09, 07:07 PM
Mike
Mike , Both the 69 and 70 Z28 used the 186" casting cylinder head, the difference being that 70,s had screw in studs with guideplates. The studs and plates were introduced in the 70 model year to combat warranty issues from pulling the pressed in studs out of the 302 with mechanical camshaft. The heads are identical except for those changes.
Old Jan 11th, 09, 09:08 PM
pdq67 pdq67 is offline
Banned
Todd,
Just pin the studs using 1/8" x 1" long roll pins and go.
pdq67
