big block spark plug wires - Team Camaro Tech
Thread Tools Display Modes
Old Jan 11th, 09, 09:37 PM
shadys69 shadys69 is offline
mike chiarito
Default big block spark plug wires
I am not happy with the way I have my plug wires ran over the top of my valve covers.I am looking for some ideas and some pictures of how u guys r runing your plug wires either on the side of the valve covers or under the headrs thanks guys and what wires r u runing?
Old Jan 12th, 09, 05:21 PM
BigBlock1969RS's Avatar
BigBlock1969RS BigBlock1969RS is offline
Ed
Default Re: big block spark plug wires
Here is what I did (Billet Specialties tie downs):
I had the Moroso ones before but they dumped my new set of wires onto the headers Expensive mistake, least now with the billet Specialties ones the wires aren't going anywhere. Also added the MSD silcone boot covers as well for added protection.
I have seen some trick ones where they route them under the headers, I'm sure someone will post some pics of that.
Old Jan 12th, 09, 06:52 PM
Creeper Creeper is offline
Tech Team
Robb
No pics, but I am using Taylor Spiro Pro and cant say enough about em. 135 deg boots and I ran them around the back of the v/c just using the simple clamp together seperators.
67 Camaro Project in progress
98 Camaro Z-28
72 ChevellePump Gas 468
373/9.5" converter/ TH350
Best 10.70 @ 123
Old Jan 12th, 09, 06:58 PM
ddx77's Avatar
ddx77 ddx77 is offline
Lifetime Gold Member
Drew
I am also running Taylor 9mm wires with 90 degree boots under my headers and I am extremely happy with them.
I'd post pics but I am embarassed about the condition of my headers.
________________________________
Camaroless for now...
Old Jan 12th, 09, 09:03 PM
mike chiarito
Come on pepes post some pics thanks for the help.
Old Jan 12th, 09, 10:55 PM
68bigblockSS 68bigblockSS is offline
Tech Team
nothing fancy, its either a factory part or the one that comes on the crate motors. somthing like 15 dollars and you can order it online or through a dealer.
(nevermind the mess)
Old Jan 12th, 09, 11:17 PM
69_OMEN_CAMARO's Avatar
69_OMEN_CAMARO 69_OMEN_CAMARO is offline
Damian
this is R&M Specialties wire seperators pn# 1102R and i made these MSD wires from scratch, to make them look nice and tight
69 camaro 427 (433)/F1-R procharger/Blow-thru E85 carb/th475/Gearvendors/FAB9 rear/calvert suspension
Old Jan 13th, 09, 02:45 PM
puppy puppy is offline
Tech Team
Justin
I love the 135 deg boots on the Taylor wires. I have a set on my camaro with stock manifolds and a set on the truck with headers, both fit very well.
'88 V-30 Crew Cab
'87 V-10
'69 Camaro SS
'52 M38
'46 Rat Rod
Word of the wise should be sufficient!
Old Jan 13th, 09, 03:00 PM
Z15CAM Z15CAM is offline
Ron
68bigblockSS and I use the same wire loom = fabricated. Note the SBC 327 3 wire bracket above #5 & 6 cylinders. I prefer the Accel 9000 Hi-Temp Universal Wires.
I've yet to find a wire loom as neat and efficient as one that you have fabricated.
Z15CAM - There was a Viper in my Rear View
This was my 70 1/2 Z28
http://www.flickr.com/photos/28082975@N04
Old Jan 13th, 09, 07:14 PM
mike chiarito
Thanks guys they all look great
  #11
Old Jan 13th, 09, 07:25 PM
1969ProStreetCamaro 1969ProStreetCamaro is offline
David
Under the header Moroso 90 degree spark plug boots.....................
"All I need is a fast machine". Steve McQueen
My Machine: 1969 Pro Street Camaro
468 CID 661 Horsepower Turbo 400
33"x19.50" Mickey Thompsons
Check Out My Camaro
661 Horsepower 468
  #12
Old Jan 13th, 09, 07:40 PM
Ed
There we go
  #13
Old Jan 14th, 09, 03:58 AM
Hot66ss Hot66ss is offline
Tech Team
I have ran these R&M's as well as the billet specialties that bigblock1969RS is running. They are both nice but be aware that the R&M are designed for an 8mm plug wire. If your like me I run MSD 8.5 super conductors, I managed to get them in the R&M's but they left some pretty deep impressions in the wire that worried me. Billet specialties makes most of their to hold up to a 9mm plug wire, something to consider while choosing.
Good luck, If I can be of any help let me know, I sell billet specialties products!
Tom Giarraffa
21st Century Performance
(310) 425-8700
Click HERE for our Wheel Sale
66 Chevelle 327/th350 373 posi
67 Velle- AFR headed 509bb V3.0 frame off resto
71 El Camino SS 396/th400/12 bolt posi
  #14
Old Jan 14th, 09, 02:56 PM
68Holdon 68Holdon is offline
Robert
When you run the wires under the header how or what do you attach them to so that they dont slump down onto the header? Thanks
There are no problems only solutions
68 Camaro, RS/SS, ZZ502, Retrotek Fuel Injection, 4 Speed.
2010 RS/2SS Black, 6 speed trans
  #15
Old Jan 14th, 09, 03:03 PM
David
Believe it or not..........I have my wires secured together with small cable ties. You have to start at the front of the engine removing all unnecessary slack in the plug wires and that along with the cable ties keeps them from coming into contact with the headers. I don't think are under the spark plug wires looms are manufactured. If they are, I haven't seen them for sale.
David F.
Check Out My Camaro
661 Horsepower 468
Last edited by 1969ProStreetCamaro; Jan 14th, 09 at 04:26 PM. Reason: Corrected a spelling error
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: big block spark plug wires
Location
Location
First Name
Human Verification
