| Team Camaro Tech Current Topic: help car barely moves | ||
| Camaro Tech General Tech Area For best results use specific forums |
2000 v6 that starts an idles fine, goes into gear fine. as of about 3 days ago when you put into gear an gas it it barely takes off. rpms goes up but it only creeps along. any help
| Sponsored Links | ||
Advertisement | ||
is this an automatic? if so check the fluids
Torque converter.
Jim |
I'm afraid it's time for a clutch replacement!
![]() ....Or a new tranny, if this is an automatic!![]()
First time poster-manual transmission or automatic transmission?
if its a manual, find a nice stretch of flat road, go about 25mph, and put it in 4th gear and floor the car, if your rpms go up very fast your clutch is slipping
also check the hydraulic fluid, it may have gone low and let air into the clutch master cylinder causing it to slip. your slave cylinder may have taken a dump also |
| Sponsored Links | |
Advertisement | |
