68Z center caps -which one is correct? - Team Camaro Tech
Restoration Corner Where originality comes first
Old Jan 31st, 09, 06:51 PM
enio45 enio45 is offline
Team Member
Default 68Z center caps -which one is correct?
I have a 68Z built month of 04 with DF ralley wheels, trim rings and center caps. Recently i was challenged that the center caps i have installed should NOT be the high hat type, but the low style like the 67's .
I'd appreciate the expert panel on 68 Z 28's to set me straight on this.
Also - will the build sheet define the type of caps this would receive?
Thanks in advance....
Ed
69 Camaro Z/28 w/window sticker and protecto
68 Camaro COPO 9737 non converted YENKO w/protecto
Old Jan 31st, 09, 07:03 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Mike
Default Re: 68Z center caps -which one is correct?
I'm not an expert on 68 z's, but they would have the high hat type. Same as 69.
Team Camaro Gold Member #14
1967 Camaro RS/z28 - one of 602 made - SOLD
1969 Camaro RS/SS L48 4 speed
1974 Camaro LT-Z/28 4 speed 33K orig miles
1979 Camaro Z/28 36K orig miles
1984 Camaro z/28 LG4 auto
acelr8 acelr8 is offline
The build sheet would only state rally wheels.The correct caps are the later style.Not the 67s.Jeff
Old Feb 1st, 09, 09:31 AM
rszmjt rszmjt is offline
Mike
They should be the tall ones like 69 and originals also have the double ribs on the inside of the cap, with beveled small retaining bolts that hold them together, with 3925805 X GW 5525804 "Canada" - on the inside of the cap. . Later replacements have the single ribs inside and washer head style retaining bolts. They usually have a date cast in side, a lot allways seem to be 2/79. Below is a link that shows the 2 ribs inside the cap. See post 446 in the link.
http://www.camaros.net/forums/showth...n+find&page=30
1994 Lumina Z34, 2655lbs. 446" Small Block, Brodix Canted Valve, lenco 5 speed, 8.21/167 Best. New Bickle Cavalier, 1810lbs for 2010. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973.
