Old Feb 1st, 09, 04:09 PM
Blade's Avatar
Blade Blade is offline
Matt
Default Have you done this yet?
Made you list of parts of your car yet?
1967 Prostreet Camaro
Engine –
431 Big Block Roller Motor
12:1 Pistons
Square Port Head
1050 Dominator Carburetor
8 Braided Fuel Lines
Electric Holley Fuel Pump
Summit Direct Aluminum Radiator
Billet Specialties Chrome Pulleys
Hooker Header Super Comp 2 1/8
Big Shot Nitrous kit
Lokar Braided Oil and Trans dip Stick
Lokar Cable Throttle
Flomaster Mufflers
Allstar Electric Fan
Transmission –
400 Turbo
2500 Stall
Rear –
Ford 9”
373 Gear Post. Track
28 Spline Mosler Axles
Suspension-
  • Front:
QA1 Shocks
Fully Adjustable Coilovers
Mustang II Rack and Pinion
2” Drop Spindles
  • Rear:
33” Ladder Bars
Center Link
QA1 Shocks
Brakes-
Front:
Slotted and Cross Drilled Rotors
Disc brakes
Rear:
Big Bear Ford Disc Brakes
Interior-
Stock Bucket Seats
Phantom Autometer Gauges Speed and RPM
Autometer Gauges: Oil, Temp, Battery, Nitrous
Covans Classic Gauges Panel
B&M Pro Stick Shifter
Frame-
Tubular Sub-frame with A-Arms and Control Arms
Subframe Connectors
Frame Rails
8 Pt Roll Cage
Wheels-
Front:
Prostars- 15x 3 ½
Rubber – 15x 15 31/2
Rear:
Prostarts- 15x15
Rubber- 15x 15x 29
Got to give the PEOPLE what they want!
Look....if you wanna be the best then you gotta take out the best!
BB 431 650hp
400 Turbo Trans
Ford 9" 4:56 gears
http://www.cs3automotive.com/index.php
Old Feb 1st, 09, 06:40 PM
rtj rtj is offline
Default Re: Have you done this yet?
I have a big stack of receipts. I'm sort of scared to add it all up.
Old Feb 1st, 09, 07:00 PM
fatblock fatblock is offline
I do not have a Pro Street..but I flat out stopped counting receipts.I can see why some would want to catalogue their parts for future referance though.Makes sence.
George
68 Camaro
8-71 blown 461 Rat
Old Feb 1st, 09, 08:44 PM
camaroman7d camaroman7d is offline
Royce
I think most projects start off with a list similar to yours. My list is a little different, I usually have it set up more as a shopping list with rounded off prices and part numbers. I mark the items off as I buy them. I make another "work" list and write down all the work I need to do and priotitize it, I mark things off as I go. This keeps you from getting side tracked when you have a lot of things to do.
That's an aweful lot of tire for a 28 spline axle. If you are starting from scratch on the rear end you might want to step up to 31, 33, or 35 splines. I assume with that 12:1 compression you plan to see more track time than street time.
Royce (NO XQSSS) Bradley
Pictures
Sound Clip
(brief sound clip, 3" exhaust through Borla Sportsman mufflers)
"If you are not part of the solution, then you are part of the problem" Me
Old Feb 1st, 09, 08:46 PM
Royce
No need to really add up the receipts the money is spent and the parts you bought are now worth a fraction of what you paid. I keep all my receipts but, have never added up any totals on any project I've built. I usually just hand over the stack/folder to the new owner.
People will ask how much do you have in it? I just say I don't know I never added up the receipts.
Pictures
Sound Clip
Old Feb 1st, 09, 09:03 PM
Mat Klemp Mat Klemp is offline
Team Member
I have the list, not for tracking cost but so that I will know what I need for servicing. What brake pads to get, belts, hoses etc.
TTFN
Mat
SSCARGO
Old Feb 1st, 09, 10:06 PM
HarleyD67's Avatar
HarleyD67 HarleyD67 is offline
Harley D
This is one of my old ones. I update it every year. I'm working on a new "service parts list" with exact part #'s for gaskets, etc...
"Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."--Dr. Seuss
I still contest that we learn life's important lessons in kindergarten.
Harley D
'67 coupe 427 SBC
60'-1.7281/4-11.83@115.59
tilley88 tilley88 is offline
Jeff
It's scary just thinking about adding it all up. I've got over 14K in mine and I have'nt even got started, yet. I consider myself a smart shopper, but I have been known to pay too much for something I really want. I also realize I probably won't get what I'll eventually have in it, but I'll enjoy the car regardless of how much I sink into it. It's all about havin' fun whether it's on the cheap or not......
I may be old and slow, but ........what the heck was I gonna say?
