Old Feb 11th, 09, 06:24 PM
camaroman7d camaroman7d is offline
Royce
Default Another Firewall Thread
I thought it would be a better idea to start a new thread rather than hijack the previous smoothed firewall thread. This section needs more threads to keep it fresh anyways. This section also tends to stick with one thread too long and get gets side tracked (IMO).
The car is a 1970 Nova and not "Pro Street" because it will only have 12" wide tires out back. Other than the tire size it will have all the goods (cage, blower, skinnies up front, etc..).
This is basically a step by step pictorial of how I like to fabricate and it might be helpful to others planning to try to do some fabrication but, don't know where to start.
Before: (I couldn't stand the "wrinkles") The previous owner also beat the firewall upi pretty good with a hammer for "clearance"
Here we go:
I'm not quite done yet. I will finish it up in the next day or two and update this post. I decided again a completely smooth firewall, I have had several cars with them and wanted something different. When finished this firewall will have a smooth lip running accross the seam. Ok I have to run tto work more on this later. I hope it halps some of the guys that don't have a bunch of experience. You can do it and it only takes basic hand tools and a welder.
Royce (NO XQSSS) Bradley
Pictures
Sound Clip
(brief sound clip, 3" exhaust through Borla Sportsman mufflers)
"If you are not part of the solution, then you are part of the problem" Me
Old Feb 11th, 09, 06:34 PM
1969ProStreetCamaro 1969ProStreetCamaro is offline
David
Default Re: Another Firewall Thread
Royce, thanks for sharing the pictures and knowledge.Keep the updates coming!!!
David F.
"All I need is a fast machine". Steve McQueen
My Machine: 1969 Pro Street Camaro
468 CID 648 Horsepower Turbo 400
33"x19.50" Mickey Thompsons
Check Out My Pro Street Camaro
648 Horsepower 468
Old Feb 11th, 09, 06:37 PM
Vintage 68's Avatar
Vintage 68 Vintage 68 is online now
John
Cool Re: Another Firewall Thread
Nice work Royce
Like the pattern details
Isn't it fun repairing some of the 'caveman' type hammer work you find sometimes
I was a bit confused at first - not used to seeing a Chevy in your shop
Wait !!! where's the Buick ???
Good idea to start threads on different aspects of fabrication
1968 Convertible
Some trucks
Other things - some of which float ...
Eagles may soar - but Guinea's don't get sucked into jet engines ...
It's never to late - okay, maybe now it is ...
WE NEED MORE COW BELL !!!
Old Feb 11th, 09, 06:48 PM
chevy 67 chevy 67 is offline
maxwell
i like the slightly smooth firewall look.mine was rotted under so i replaced the whole thing with a repo.but still had tu fill a bunch of holes.
Old Feb 11th, 09, 10:02 PM
PRO 48 Fleetline PRO 48 Fleetline is offline
George
Great color looks amazing keep those pics comming!
1948 Chevrolet Fleetline Areosedan PRO STREET!
406 Solid Roller motor!
Old Feb 12th, 09, 08:06 AM
Royce
WOW, my spelling was terrible. That's what happens when you rush. For some reason I can't edit the first post.
Here's a spelling key, lol "again" was supposed to be against, "halps" = helps, "tto" = to
I have a few screw holes to fill, no biggie and the upper portion of the firewall is in very good shape. I decided not to totally delete the wipers on this car. I will make a bolt on, block off plate for the wiper motor. That way if I want wipers later it will be a simple fix.
John,
I didn't even notice the firewall was "adjusted" until after I pulled the engine out and was cleaning up the firewall.
Pictures
Sound Clip
Old Feb 12th, 09, 08:43 AM
Skeeter55's Avatar
Skeeter55 Skeeter55 is offline
Team Member
Skip
Nice job Royce, now you can come over to weld my subframe connectors. I wish i could fabricate and weld. You guys make it look easy.
1969 SS 498 BBC 636hp@654tq 4 Speed 12 Bolt posi-373 (The Orange Crush)..http://i145.photobucket.com/albums/r...5/Image002.jpg
Old Feb 12th, 09, 09:28 AM
prostreet69camaro's Avatar
prostreet69camaro prostreet69camaro is online now
Mike
Looks great Royce,
Have you thought about relocating the wiper motor to the firewall / cowl area under the drivers fender? I have seen a few pictures on here about it.
Mike
69 Camaro Prostreet - purple w/ghost flames , 502 w/ 871 blower
http://s268.photobucket.com/albums/j...treet69camaro/
Old Feb 12th, 09, 03:25 PM
Royce
Skip,
You can do it! Seriously it's not hard. TIG welding takes some practice/talent but, just about anyone can MIG weld. When I bought my first wire feed welder (long time ago) I had my wife welding in about 15 minutes.
Fabricating just takes an imagination and patience. If you can picture it in your head, you can make it.
Do you have bolt in connectors that you want welded or weld in connectors?
Pictures
Sound Clip
Old Feb 12th, 09, 03:28 PM
Royce
Originally Posted by prostreet69camaro View Post
Looka great Royce,
Mike,
I have never heard of this. If you get time, share some info about this. I would be interested in taking a look. I normally don't run wipers (not really needed here) we don't have thunder storms for out of nowhere like other places. You know well in advance if there is a chance of rain and I usually don't drive my toys in the rain.
Pictures
Sound Clip
Old Feb 12th, 09, 03:32 PM
Skeeter55's Avatar
Team Member
Skip
Originally Posted by camaroman7d View Post
Skip,
See there you go making it sound so easy... lol.. Yeah i have the Hotchkis frame connectors, that are both a bolt in and or weld. I think what im gonna do is grind and clean up the metal to be welded and bolt it in, then drive it to my buddy's shop and have him weld it... He wont let me touch his welder.
Old Feb 12th, 09, 05:52 PM
Mike
Mike,
Royce,
The one I saw was they cut out the mounting flange for the wiper and moved it to the cowl area under the drivers fender. That way the factory motor could be reused. Then they modified the arm to reach the motor. I looked for the thread but could not find it.
Here is one way of doing it.
http://www.lateral-g.net/forums/show...ighlight=wiper
http://www.camaros.net/forums/showth...ht=wiper+motor
Mike
Old Feb 12th, 09, 05:55 PM
Mike
I just put in the DSE subframe connectors in the protouring 69 I am doing. They are the weld-in type. It wasn't that hard to do. The only thing I dont like is they stick up about 1-1/2" into the rear floorboard.
Mike
Old Feb 12th, 09, 07:56 PM
Royce
Skip, It's always good to have friends like that. I wouldn't have a problem doing it for you but, my little shop is full of Nova right now. Better yet I would let you do it that way, you would be hooked.
Pictures
Sound Clip
Old Feb 12th, 09, 08:04 PM
Royce
Royce,
Just great Mike! Now I have to add that to my list, I was trying to keep this built simple and short, lol. Thanks for looking that up for me. I like the idea of sticking the GM wiper motor under the fender. I'll look into it, for sure.
Pictures
Sound Clip
