PG or not to PG - Team Camaro Tech
Old Feb 15th, 09, 06:13 AM
Greg 67SS/RS Greg 67SS/RS is offline
Tech Team
Default PG or not to PG
I'd like to hear opinions and experiences on PG, 350TH, or 4 speed transmission conversions. I'm going crazy trying to decide what to do, so I'm asking for some advice.
I have a 67 ss rs with a 350 v8. I'm keeping it the original color,adding new shocks and springs and lowering the suspension about 2", adding new disk brakes, adding headers to the ORIGINAL rebuilt 350 V8. The car came w/o a tranny so I can pick and choose. The options I'm considering:
1) PG tranny to keep the drivetrain original
2) 350 TH because I like the idea of 3 speeds but conversion might be expensive and difficult and also involve the console.
3) Muncie 4 speed M-20 and same concerns as above.
Please advise, I'd like to hear your stories. The good ,the bad, the ugly.
Old Feb 15th, 09, 07:05 AM
Andrew69's Avatar
Andrew69 Andrew69 is online now
Andrew
Default Re: PG or not to PG
If you have to buy a new tranny anyway make it a 4-speed. There's nothing like rowing the gears in a first generation.
Skunk Works
302DZ, M22W Muncie, 12-Bolt Rear 3.73
Some photos: http://www.camaros.net/showroom/show...0&ppuser=11587
Member # 159 (Formally known as X33D80)
Old Feb 15th, 09, 07:16 AM
onovakind67 onovakind67 is online now
I'd go with a TH350. They're much easier to find than a PG and you'll like the first gear better. You don't have to modify the console, the original PRNDL setup will work just fine.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
Old Feb 15th, 09, 07:41 AM
Melrose RS Melrose RS is offline
Tom
Don't even consider the PG. They make whining noises and thwart your ability to spin tires unless you have a lot of power or 4.10 rear gears.
The TH350 is bolt in, easy weasy.
The 4 speed would be more fun, but also cost more when you add in pedals, linkage, shifer, clutch, flywheel, bell housing, console parts etc.
'67 rs - ordered new by my Grandfather
327 L30, K-K, Deluxe int, tach & gauges, 12 bolt posi, 4 speed.
(And an 8 year old riding shotgun. )
the Melrose rs - L30 327/275hp
Old Feb 15th, 09, 08:02 AM
Philip Philip is offline
Team Member
My choice would be a Tremec TKO 600. Your Camaro is one of the few body styles that this transmission will fit in without modifying the floor.
Old Feb 15th, 09, 08:19 AM
KevinW's Avatar
KevinW KevinW is online now
Kevin
Get the best of both worlds, a 200r4, 4 speed overdrive, same size as the PG, dont have to cut the driveshaft, better first than a TH350, TV and shifter conversion readily available! I am going to put an 86 Monte SS 200r4 to replace my PG!
Old Feb 15th, 09, 08:49 AM
deerhunter deerhunter is offline
My choice too! I bought mine from Classic Motorsports Group this winter. The ice is gone but it is still cold enough there was no mud so I took it out for the first time. Very nice! Shifts very easy, quiet, and I like rowing through the gears!
Old Feb 15th, 09, 09:14 AM
Everett#2390's Avatar
<Jake 68's Rule
I would think it depends on how much work you want to do.
If the car came with a PG, and to remove the lack of first gear ratio when compared to a TH350, install a looser convertor, say a 2400 stall or Sat Night Special. This convertor will level the field. Of course, you'll had to add an external cooler in series with the existing rad cooler.
As suggested, a TH350 with 6-inch tailshaft is a direct bolt-in and a 2400 stall convertor would wake it up also. Again, an additional cooler will be needed.
A TH200-4R is good, but you need a TH400 crossmember, I think. OE Driveshaft will install.
If going manual, you'll have to get pedals and the like since apparently, the car did not come with a std trans.
Most important, its your car and you need to decide for yourself to figure how & what you want to configure it.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Feb 15th, 09, 10:20 AM
77thor's Avatar
77thor 77thor is offline
Fred
I would go with a modern trans (w/overdrive)..... I would not convert it to a manual,
although I do like to shift thru the gears..........
1969 Camaro SS 350, M21, 12 Bolt Posi
Old Feb 15th, 09, 07:02 PM
arocars arocars is offline
The simplest bolt on would be a short shaft t350. They are common and cheap. They use the same driveshaft and crossmember as a powerglide. The 2004r is not a direct bolt in. (The t400 crossmember is close but not close enough (IMO) for an easy conversion.) 4 speeds, 5 speeds, 6 speeds are fun, but the final price, once installed, will be considerably more than installing a t350. Powerglides are no fun to drive in a street car.
Old Feb 15th, 09, 07:09 PM
An old guy around here had a favorite saying...."You just can't put a price on a good time" although, if you are like me, yes you can, you have to. It took me quite awhile before I was able to get the TKO 600.
Old Feb 15th, 09, 08:25 PM
Tech Team
I've been doing a lot of reading on this site today. Now I've got it down to the Th350 or the 2004r. The gears are 3.73 and what else could I do to get better hwy mileage if I went with the TH350?
Keep it going guys.
Old Feb 15th, 09, 08:48 PM
BPOS BPOS is offline
Al
3.73 and a t350 wouldn't be much fun on the freeway. 3.73 and a 2004r is perfect. Plus lockup is nice also.
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
Old Feb 15th, 09, 09:25 PM
mike p mike p is offline
Tire height plays a role in rpm at highway speeds. If you don't have an overdrive transmission, taller tires or taller axle gear (3.55, 3.36 or 3.08) would help reduce your highway rpms.
1968 327 sport coupe. Son of original owner.
Old Feb 16th, 09, 12:12 AM
Lurchhammer Lurchhammer is offline
Tech Team
Paul Church
I had a racing powerglide with a lower first gear and a transbrake. It was miserable on the street because 2nd gear takes forever to wind up. They're only good for racing in my opinion. High horsepower cars benefit from more consistent ET's with a glide.
