Old Feb 15th, 09, 02:09 PM
tillman tillman is offline
Tech Team
Tony
Default 1969 camaro tire size
I have started back halfing my 1969 camaro and dont want to stretch the wheel wells.I want to use 29x18.5 or 29x12.5 prostreet radials.Anyone out there have some pics of this set up the could send to me?
Tony tdtillman@gulftel.com
Old Feb 15th, 09, 04:19 PM
Tech Team
Tony
Default stretching feners
Old Feb 15th, 09, 04:26 PM
john68 john68 is offline
Team Member
John
Default Re: stretching feners
69 is a lot easier than 67/68, there is a full radius, 69 cut in the center of 1/4 thru
crease, cut across top, cut down front and rear of wheel well opening, move front and rear peices to clear tires, cut the space out reweld those peices in make a 2-3-4 inch
peice to filll the wkeel well spread.
Old Feb 15th, 09, 04:43 PM
Tech Team
Tony
Do you think I need to stretch with a 29 tall tire?
Old Feb 15th, 09, 04:50 PM
Team Member
John
Probally not I run 33" on a 68, I had to cut rockers an all 24' wide tubs, Borrow a tire and check fit.
Old Feb 15th, 09, 05:21 PM
ls427ss ls427ss is offline
Larry
hang on a few minutes, I told you I would post some pics 2 days ago and had to leave. Let me move my Chevelle out from under the rack and will post some pics for you. Do you want with or without tires? Mine is on the rack so the rear end is hanging down, but I have no problem at all with removing 29X18.5's on 15X14 wheels with a floor jack under the diff. Heres a couple for now from before it was taken apart... The body has been dropped down over the frame now, so it will be a lot lower> approx 1 1/2" in rear and 5" in front...
Sometimes it's better to let someone think your an idiot, than to open your mouth and remove all doubt...
ProStreetCamaro.com
68 Camaro project photos
Old Feb 15th, 09, 05:52 PM
Larry
Default Re: 1969 camaro tire size
did the pics I posted help, because it's raining, so unless you respond I will wait to put my car in the rain. If you need a specific pic of something let me know and I will try to help you out..
ProStreetCamaro.com
Old Feb 15th, 09, 07:16 PM
prostreet69camaro's Avatar
prostreet69camaro prostreet69camaro is offline
Mike
Look at this post. PROZ11 has the same tire you are talking about on a 69. PM him for some more pictures.
http://www.camaros.net/forums/showthread.php?t=151102
Mike
69 Camaro Prostreet - purple w/ghost flames , 502 w/ 871 blower
http://s268.photobucket.com/albums/j...treet69camaro/
Old Feb 15th, 09, 07:55 PM
DonCasanova DonCasanova is offline
Tech Team
Tony - When we backhalved my 69, the stock quarters took 29's nicely. Later went to 31's and had to stretch the front and rear fender lips to match the inner lips. Not that big of a job, and the 31's look better on my car than the 29's.
On page 2 of Pro Street, under "Video of our 69 BB", there is some footage that may help. Good luck.....................DC
Old Feb 16th, 09, 05:46 AM
PROZ11's Avatar
PROZ11 PROZ11 is offline
MARK
Tony,
Let me know if you need any pictures. I would be happy to email you some or post them here.
Mark
Pro Street Z11 clone
http://img183.imageshack.us/img183/8...mart010ce4.jpg
Old Feb 16th, 09, 03:17 PM
Tech Team
Tony
Mark
Thanks for the info I would like to see more pics
Old Feb 16th, 09, 04:35 PM
PROZ11's Avatar
MARK
Originally Posted by tillman View Post
Mark
Pictures emailed...
