| Team Camaro Tech Current Topic: Eastwood Air Kit | ||
| Tools & Shops Shop Rat HQ |
I was going to start planning my first 'real' air compressor system for my garage. I am planning on buying the IR-30 7.5 HP system, so that I'll have plenty of air for painting, air tools, and using a blast cabinet. I will be running air lines to two separate areas of the shop. I was going to put in a standard black pipe system, but ran across a tubing system from Eastwood:
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT Has anyone used this type of system ? One concern I have is dips in the line where moisture could build up. I don't see a way to put in water traps in this system, but I suppose you could work something up. I also was not sure if 1/2" is large enough as that is about the same size as an air hose. Anyone use one of these ? -Kevin
'68 RS Camaro, 454 SBC '69 Camaro, body only |
Those systems do not thrill me. I like the hard pipe. you can pipe in the proper drainage, and water traps. it is rigid with no hose flopping when you try to connect or disconnect.
TTFN Mat
SSCARGO |
I ran 3/4" around my shop and have 1/2" drops to the seperator,oiler,regulators.I would reccomend running 1" with 1/2" drops and jump up off the mains for the drops and pitch the lines back to the compressor.I have two of these compressors and have had no issues for 7 years.When I bought mine they were $1000 now they are $1200 but I think they are well worth it.Here is a link they are nice to deal with.
http://www.eatoncompressor.com/catal...747/172993.htm |
Never tried the flexible stuff, but mine is done with high pressure PVC...feeds both garages...paint,blast,air tools......5 years and not a problem and quite inexpensive
Roger 67 RS/SS350 |
Do you mean schedule-80 (grey) PVC ? I've heard of people using that but was unsure. My one concern with black pipe is eventual rusting and I just think its going to be a PITA to work with.
-Kevin
I am going black pipe. I have seen a PVC air system explode, and its not pretty. Black pipe would probably last 80 years.
OK, I'm sold. Black pipe here I come !
-Kevin
I did a little google research and there is a lot of debate on the right stuff to use.....rust and corrosion being one concern with black pipe...explosions with PVC being another...there is a specific ABS plastic made for high pressure...but you really could research this on google and find a milllion opinions...good luck !
Roger 67 RS/SS350 |
Heres this Kevin if it will help. You don't have to have an air dryer or dessicant cans.
http://www.1969supersport.com/draw1.html Rob
"There are questions to be answered, and answers to be questioned" Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything. http://www.1969supersport.com |
1969ss:
Your link has been one of my bookmarks on how to setup an air system. I hope to come up with something similar when I complete mine. Thanks -Kevin
#11
I'm running 1/2" copper for my air lines, but I'm not under pressure all the time. I have a solenoid at the compressor that shuts off when I shut the compressort off.
Jeff |
