350 crank in a 327 block... - Team Camaro Tech
Thread Tools Display Modes
Old Sep 16th, 03, 01:24 PM
RyanP1 RyanP1 is offline
Tech Team
Post
I have a 327 ( 327 1968 casting number with large journals) bored 0.060 over.
I want more torque.
Can I bolt in a 350 crank, change pistons and go? Will I have to do any grinding?
Correct me if I am wrong, but I would think grinding to be unnecessary... aren't 327/350 blocks the exact same? Isn't the only difference the stroke and piston height?
Thanks!
Old Sep 16th, 03, 01:43 PM
stingr69 stingr69 is offline
Post
You are correct.
-Mark.
Old Jan 16th, 11, 10:19 PM
8secs-10 8secs-10 is offline
tritt
Default Re: 350 crank in a 327 block...
how bout it im just a local gear head with high hope and alot of questions,i,ve got a 1971 350 engine i just purchased the problem with it is the block is busted at the corner bolt for the outside starter bolt,i also have a 1968 327 part #3914660 not sure of the journal size( if anyone with info please help) can i take the guts from the 350- rods pistons etc.. and interchange with with 327 block without machine work or what would be the best route? PLEASE HELP thanks to all!
Old Jan 16th, 11, 10:40 PM
kettbo kettbo is offline
George
68 327s have the '350-sized' mains so you can put the 350 parts in the 327 block
this is to say if the bores are the same
you could also have the block repaired...pretty common problem
George Kettler
US ARMY Retired, Scouts Out!
o 70 Elky 454/3000 stall/3.42 gears
1.632 60ft, 11.726 ET, 113.49mph
o 68 Vette 427, owner 23 years
o 68 Camaro Rallye Green Vert 327/2004R/3.73 http://www.camaros.net/forums/showth...183654&page=68
Old Jan 16th, 11, 10:46 PM
camaro_fever68's Avatar
camaro_fever68 camaro_fever68 is offline
Ray P.
Just had an outside starter bolt repaired in a 400 block. Cost me 75.00.
Ray
Old Jan 17th, 11, 06:08 AM
tritt
thank you guys very much its hard to get good info on these things sometimes but could i just take it to a machine shop or any good suggestions for the area
Old Jan 17th, 11, 08:29 PM
Joe Harrison's Avatar
Joe Harrison Joe Harrison is offline
67 Camaros Rock
or you can go 400 crank and stroke it to 383 and have the numbers of a 327 and badge as a 327, leave stock looking like the 327 and have real sleeper looking small block.
"If you can leave black marks on a straight from the time you exit a corner till the time you brake for the next turn.......
Then, you have enough horsepower."
-Mark Donahue
My 67 Camaro Time Line http://www.camaros.net/forums/showthread.php?t=211805
Old Jan 17th, 11, 11:30 PM
TJS69 TJS69 is offline
Tom
Smile Re: 350 crank in a 327 block...
Usually if you put in a 400 crank, you will have to do some clearancing (grinding). Also the mains will need to be machined larger if you use a stock 400 crank. The aftermarket has 3.75" stroke cranks with 350 mains.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
Old Jan 18th, 11, 07:48 PM
67 Camaros Rock
Clearancing of the block yes.....machine work on the mains in the block no. Strokers have been built for many years using 400 cranks in 350 blocks, the 400 mains are turned down .200 to fit the 350 block at STD bearing sizes. The 68 327 block is the large journal block. It's a basicly a 350 block with a 307 crank....which gives you a 327. The 307 was the engine that replaced the 327 about mid year in 1969.
-Mark Donahue
Team Camaro Tech > All Generations > Performance      Current Topic: 350 crank in a 327 block...
Location
Location
First Name
Human Verification
