Positraction Differential lubricants - Team Camaro Tech
Thread Tools Display Modes
Old Mar 7th, 09, 11:25 PM
69Camaro350 69Camaro350 is offline
Julio
Default Positraction Differential lubricants
As I was changing the oil in the rear differential, there was a tag that says Positraction differential lubricant only, is there a difference in lubricants. I was going to use 85W-90W, is that ok or should I look for a lubricants specifically for positraction?
Old Mar 8th, 09, 03:44 AM
wagonman's Avatar
wagonman wagonman is offline
john
Default Re: Positraction Differential lubricants
Use the 85W-90W as you planned.then use some posi additive.It's a little small bottle 6oz or so.......
you will find it at almost any parts house.....
Remember,I'm not making this stuff up!
1969 rs/ss 396 350hp/4spd conv a/c,pw,ps,foldown
1968 Z/28 crossram- j/l8 conv pw,ps,foldown
1963 nova ss 350/4spd conv a/c,ps,pt
1963 nova 400 4dr 6cyl/700r4 a/c
2006 GT/5spd mustang conv
Old Mar 8th, 09, 06:08 AM
DOUG G DOUG G is offline
Get the GM posi-trac additive (2 bottles) and you'll be good.
68 Camaro~LSx
Best to Date....and tuning
1.546 60'
7.132 @ 94.43 660'
11.327 @ 116.79.
RedЯum <-Pics
https://youtu.be/Of8WVNYhR1g <~More here
Old Mar 8th, 09, 09:41 AM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Or you can use Amsoil synthetic gear lubes, they have the additive built into it already plus it will run cooler for you as well.
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r
Photos of my Camaro for viewing
Old Mar 8th, 09, 10:18 AM
Julio
Thanks team for the info.
Old Mar 8th, 09, 10:21 AM
go2fast go2fast is offline
Jim
Do you sell Amsoil?
Old Mar 8th, 09, 11:24 AM
BigBlock1969RS's Avatar
BigBlock1969RS BigBlock1969RS is offline
Ed
Anyone know off hand how many quarts does a typical 12 bolt rear end take?
Old Mar 8th, 09, 12:17 PM
tgifford5 tgifford5 is offline
Team Member
Ted
About 2 qt. is what I used. I also use Royal Purple it has the additive in it also.
Old Mar 8th, 09, 12:46 PM
big gear head big gear head is offline
Freddie
2 quarts of oil and one bottle of GM or Ford additive. Don't use the additive that you get at the auto parts store unless it's GM or Ford. Use only one bottle of additive unless you have an Auburn, then use 2 bottles.
Old Mar 8th, 09, 12:55 PM
Badbird's Avatar
Badbird Badbird is offline
Banned
Ron
What exactly does this bottle of posi additive do?.....Is it an anti foaming agent to prevent the gear lube from foaming?
  #11
Old Mar 8th, 09, 01:02 PM
Steptoe Steptoe is online now
Steps
Redline 75/90 has additive in it and they also have the additive separate.
  #12
Old Mar 8th, 09, 01:14 PM
Gary L's Avatar
Gary L Gary L is offline
"Tri-Tip"
Modifies the lubricant so the clutches slip better going around a corner. No chattering.
"Government is not reason; it is not eloquent; it is force. Like fire, it is a dangerous servant and a fearful master." ..... George Washington
Gary,TC Member with a Lemans Blue/Ivory 02D X33, DZ, M20, MS, flat hood. Only the BU code rear end is original.
  #13
Old Mar 8th, 09, 01:25 PM
Freddie
Yea, it makes the clutches slip easier.This kind of goes against the purpose of the clutches in the first place. That is why you should only add as much additive as you need. Too much additive makes the posi less effective.
  #14
Old Mar 8th, 09, 01:38 PM
click's Avatar
Moderator .. Jim
Jim
Myself and BigGearHead both have Amsoil available for you, through ordering direct from Amsoil if you want.
PM either of us
  #15
Old Mar 8th, 09, 05:02 PM
FBODY FBODY is offline
Daniel
In my 69 10 Bolts, I used GM oil (80W90, P/N 89021671) with one 4oz bottle of GM Limitted Slip Axle Lubricant Additive (P/N 1052358).
Daniel,
1969 SS-350 Camaro, Hugger Orange
2005 Black Mustang GT
http://community.webshots.com/user/fbodyss1969
http://www.fbody.pa.20fr.com/home.html
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Transmission & Driveline      Current Topic: Positraction Differential lubricants
Location
Location
First Name
Human Verification
