| Team Camaro Tech Current Topic: Husky pro air compressor? | ||
| Tools & Shops Shop Rat HQ |
Anyone think this compressor will work for a two person auto repair facility reliably? Husky part # hs7810. Here are the specs on it. I was going to order a IR dual stage 175 psi 60 gallon tank, but it's 1700.00 and i can get this Husky compressor for 1000.00. The Husky is also dual stage. Please let me know what ypu guys think. Thanks
*Husky Pro Air Compressor (HS 7810) 2 Stage 80 gal tank 4 hp motor 12.2 SCFM @ 175 psi 12.6 SCFM @ 90 psi 175 psi max 240 v
1972 Rally Nova. 496 bbc. Turbo 400 w/2.75 tci 1st gear. Moser 9" w/3.73, Detroit locker and alloy axles. Last edited by Dougs72Nova; Mar 8th, 09 at 08:14 PM. |
I have been told the lower RPM motors is a good comparison.My 5 hp is 1560 cheaper ones are twice this.Try Eaton this is where I got my compressors.
http://www.eatoncompressor.com/page/page/504747.htm |
12 cfm isn't a whole lot, but depends on what you're going to do with it. Are those typical stats for a 4hp/2stage? I haven't looked at comps in several years.
Ive read that SCFM isn't a "true" rating, but that ACFM is more realistic.
Driving a #s-matching Z in the rain..... and lovin' it.... ![]() TheMuscleCarGuys.com "Build them how the designers and engineers envisioned them to be." |
The IR compressor i am looking at is 15.6 scfm @175 psi, but it only has a 60 gallon tank. What do you guys think? Is it worth the extra 700.00? Thanks.
1972 Rally Nova. 496 bbc. Turbo 400 w/2.75 tci 1st gear. Moser 9" w/3.73, Detroit locker and alloy axles. |
This is the one we've been running for 4 years. 22 max, 18@100psi. Haven't bogged it down yet, even with a DA and blast cabinet simultaneously.
http://www.industrial-air-compressor...essor-3-2.html
Dave. Is that single stage?
No, it's 2 stage.
"These air compressors include a top-quality, heavy-duty T39, 2 stage compressor with oversized ball bearings, industrial grade balanced pistons, cast iron cylinders, and long-life oil seals."
Thanks. I'm going give them a call tomorrow.
