Tools & Shops Shop Rat HQ
Old Mar 10th, 09, 01:16 PM
Gambitt's Avatar
Gambitt Gambitt is offline
Team Member
Jason
Question Air Compressor specs...
I will soon be in the market for a new air compressor for my shop. I will be doing the normal hobby related things, using air tools, maybe even paint an occasional car or two. I've been looking at a Quincy. Here are the specs:
cfm: 15.7 @100psi, 15.2 @ 175psi
60 gallon tank
5 Horsepower
two stage
compressor rpm:1310
motor rpm: 3450
Does these specs seem okay for what I intend on using it for? This particular compressor is $999. I can jump up to the next size (or maybe 2 sizes) bigger for an additional $500. I don't want more than I need, but I don't want less either.
My Car (69 RS/Z28)
Gambitt
Old Mar 10th, 09, 02:11 PM
Sauron67MM Sauron67MM is online now
Scott
Default Re: Air Compressor specs...
Which model? Quincy has many. I have one in the warehouse waiting for me, 241C80VCB-$1,499(reg 1,699), but I can pick it up. Other companies offer free shipping. Ram Air Dave posted a company ( http://www.industrial-air-compressor...essor-3-2.html ) also that has free shipping. Better to get one with a better motor such as Baldor or equiv. Lower RPM's at 1725 are better as opposed to your choice at 3450. Aftercoolers on the oulet lines are a plus of a good design. If you have to burp for shipping you may want to get a comparable model/company w/ free shipping. If Dave's recommendation still stands I may go that route instead. There are other good compressor companies. You get what you pay for in a compressor, Skimp and it'll cost you more in the long run.
Old Mar 10th, 09, 02:55 PM
DOUG G's Avatar
DOUG G DOUG G is online now
My CambelHousfield <sp> is 6hp,60gal,125, 9.5 @ 90.... keeps up with everything I do... including blowing off the riding mower and driveway
Paint gun
blow gun
air ratchet
impact gun
air chisel
Doug G.-406ci
Camaro Pics ~ AKA: RedЯum
1.643 - 60'
7.511 @ 91.33 -660'
11.823 @ 113.52 -1320'
Old Mar 10th, 09, 03:02 PM
Gambitt's Avatar
Team Member
Jason
I'm looking at the QT54. Shipping is not an issue, our local Rural King has them in stock. This model does have a Baldor motor on it. It also has a 2 year warranty on the pump and a 5 year on everything else. I am not looking to skimp, I just don't want to over-buy on a compressor that will mostly be used for weekend work, but I do want one big enough and that will last a long time.
My Car (69 RS/Z28)
Gambitt
Old Mar 10th, 09, 03:07 PM
Pro-Street69Camaro468 Pro-Street69Camaro468 is offline
Gold Member
Dave C
I have been told the lower rpm motors are better.Take a look at Eaton they are real nice to deal with. heres a link.
http://www.eatoncompressor.com/page/page/504747.htm
Old Mar 10th, 09, 03:38 PM
Gambitt's Avatar
Team Member
Jason
If I go with the next model up on the Quincy that the store has in stock, it does run at a lower rpm...so it is worth the extra $500-$600? I don't mind spending that much more if that is what I need.
My Car (69 RS/Z28)
Gambitt
Old Mar 10th, 09, 04:10 PM
Gold Member
Dave C
This is information I got from Eaton as far as the RPM go's and they do run quieter for sure I would give the guys at Eaton a call and check there web site out they are very informative.
Old Mar 10th, 09, 07:17 PM
Gambitt's Avatar
Team Member
Jason
I don't think I have any local places near me that sells Eaton...and that is a major consideration.
My Car (69 RS/Z28)
Gambitt
Old Mar 10th, 09, 07:35 PM
Scott
I was only considering RamAIrDave's Bel-Aire because it puts out more cfm for the same coin as the Quincy and free shipping. I picked up a Quincy Model 271 7.5 HP for my friend's shop for $2600. Nice and quiet. I don't need that much so I went with the 241. They make good compressors. So do other companies. Bottom line is shipping and who's got a better price for the same quality and specs. Like I said, I can pick it up.
Old Mar 10th, 09, 07:47 PM
RamAirDave RamAirDave is offline
Team Member
Dave
I certainly wouldn't say the B-A comp we have is the best/$$ out there since I haven't looked at comps since we bought it, just the one we've been using for almost 4 years now with good performance/cfm and zero problems. Ive never checked which motor it has or the rpm.
We bought it through our paint supplier, so it was pick-up. Just a quick google of the model # 318VN shows a few places that have free shipping and/or may be more nearby to you.
Driving a #s-matching Z in the rain..... and lovin' it....
TheMuscleCarGuys.com
"Build them how the designers and engineers envisioned them to be."
Old Mar 10th, 09, 08:00 PM
Gambitt's Avatar
Team Member
Jason
Thanks for all the information guys...I will let you know when I purchase something.
My Car (69 RS/Z28)
Gambitt
Old Mar 20th, 09, 02:46 PM
Gambitt's Avatar
Team Member
Jason
I got around to checking on a Quincy that does run at a lower rpm. The first model to fall into that category is over 3k. If they are all like that, I will be going with a higher rpm, even if it doesn't last as long and is noisy.
My Car (69 RS/Z28)
Gambitt
Old Mar 20th, 09, 03:31 PM
Scott
They are not all that expensive for the 1725 RPM models. There is a multitude from which to choose. $3000 will buy you one with a 15 HP motor. More motor than what you need it for. Look at the smaller models.
http://www.tools-plus.com/power-tool...tationary.html
Old Mar 20th, 09, 09:45 PM
yellow69RS's Avatar
yellow69RS yellow69RS is offline
Jeff
If I was buying a new compressor today I'd pick a price point and shop every compressor I could find in the range (+ or _ $100) including shipping. I'd buy the one with the most CFM. Properly maintained you probably won't wera otu even the cheapest built compressor doing what you do. I bought a Puma Compressor from Builders Square close to 20 years ago and haven't worn it out yet. I replaced the motor early in it's life becuase of oversray on the armature caused it to burn out. That replacement has been running it ever since. Just my .02
Jeff
Old Mar 23rd, 09, 09:31 AM
Gambitt's Avatar
Team Member
Jason
Thanks for the link to tools-plus.com. They do have some that are cheaper than 3k, but it looks like most of them are 3 phase. Is there another brand of air compressor that runs the low rpms that can be purchased at a place like that for around $1500?
My Car (69 RS/Z28)
Gambitt
