14015445 hi po pas - Team Camaro Tech
Thread Tools Display Modes
Old Mar 10th, 09, 04:13 PM
camfreak1 camfreak1 is offline
Default 14015445 hi po pas
Hey guys I have a 14015445 454 and also reads Hi Performance Passenger What would this engine come out of.
Old Mar 10th, 09, 05:00 PM
1969ProStreetCamaro 1969ProStreetCamaro is offline
David
Default Re: 14015445 hi po pas
14015445...454.......78-90...2 or 4 bolt.
David F.
"All I need is a fast machine". Steve McQueen
My Machine: 1969 Pro Street Camaro
468 CID 661 Horsepower Turbo 400
33"x19.50" Mickey Thompsons
Check Out My Camaro
661 Horsepower 468
Old Mar 10th, 09, 05:25 PM
TJS69 TJS69 is offline
Tom
Smile Re: 14015445 hi po pas
The casting number won't tell you much, as we were told above, by David. The engine ID number or the VIN would tell us more.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
Old Mar 11th, 09, 09:33 AM
Guys it has these numbers on the stamp pad. CBZ140873
Old Mar 11th, 09, 09:41 AM
Hey guys here is the date code E29 8 code on stamp pad is CBZ140873 Casting 14015445
Old Mar 11th, 09, 09:53 AM
69 z11 69 z11 is offline
Jerry
Is it possible the B is really an 8? I think you have a 1978 truck engine, installed at the Fremont CA plant.
69 Z11 03D Van Nuys
82 Z28 Gordon Johncock's Pace Car
97 30th Z28 6 speed vert 1 of 175
A Pair of Huggers at the Car Show
Old Mar 11th, 09, 10:52 AM
Clearly stamped on the block is PASS HI PER thats what has me stumped. Lets see what you guys can find. Is it possible it came in a police car.
Old Mar 11th, 09, 11:01 AM
Jerry
Do you have the head casting numbers?
69 Z11 03D Van Nuys
Old Mar 11th, 09, 11:05 AM
Jerry
73-84
454 BLOCK ID # 14015445
VIN CODE "L,S,W,Z"
HEAD ID # 336781, 346236, 353049, 6272292
Notes: Carb, 10-35 series, w/o H5D emissions
85-90
VIN CODE "W,Z"
HEAD ID # 14081045, 14092360, 10052902
Notes: Carb, 10-35 series w or w/o H5D emissions
69 Z11 03D Van Nuys
Old Mar 11th, 09, 11:25 AM
Heads are 353049 clearly 396. What car from 1973-1990 would have had this engine in it. Thanks
  #11
Old Mar 11th, 09, 12:22 PM
Tom
I agree with 69 z11. From your date code E29 8 it was manufactured May 29th of 1978.
The Heads are :353049....1970-73.................. 402/454....2.06.....1.72...... Open........113
OR................ 353049.....73-84...oval.............454......................... ....Open 122cc chamber, 255/119cc ports
What are the date codes on the heads ? - May not be original to the engine
As far as I know, there were not ANY big blocks put in cars, only pickups in 1978. the 10-35 was the older designation for 1/2 ton pickups to the 1 ton pickups. This is not a "Truck" block, but the "car" block that was used in the light duty pickups and cab and chassis units
  #12
Old Mar 11th, 09, 01:52 PM
Jerry
The 049 heads are really good ones, maybe the best factory oval ports made. They are open chamber heads, never installed on a 396 from the factory, first produced in 73. Those heads with the 4 bolt block would make a really nice 496!
69 Z11 03D Van Nuys
  #13
Old Mar 11th, 09, 03:00 PM
PowerWindows PowerWindows is offline
Jim
AFAIK, all BBC engines had that (PASS HI PERF) cast into the block.
67 Camaro: 454/TH400/4.10 12 bolt. Lots of options: PS/PDB/PW, tilt, tach, gauges and more. K-K + 797-Z...
"Politics is the art of looking for trouble, finding it whether it exists or not, diagnosing it incorrectly and applying the wrong remedy" - Sir Ernest Benn
  #14
Old Mar 11th, 09, 03:18 PM
Jerry
No, most MK IV blocks are not marked that way. It might seem that way now, because we all we see are the HP blocks and the standard ones end up in the scrap yard. The HP blocks also have the oil cooler holes that the regular blocks didn't have.
69 Z11 03D Van Nuys
  #15
Old Jul 3rd, 10, 09:52 PM
RogerBBC RogerBBC is offline
Roger
Guys I have 454 BBC with the casting number on the bellhouse driverside 14015445 and in thecentral bellhouse area states GM 112 and a leter P, is it a hi po version?? a passenger car version?? I just know that it is a 78-90 2 or 4 bolt 454, I haven't seen the vin info yet, and soon I will check the heads code.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: 14015445 hi po pas
Location
Location
First Name
Human Verification
