1967 Wheel and Tire Combo's...
144K views 6 replies 1 participant last post by  DjD
#1 · (Edited)
Taken from: http://www.camaros.net/forums/showthread.php?t=100853 Just '67s with wheel and tire sizes given...
A/R Ansen sprints
17x7 with 4" BS and BFG 225/45R17's up front and
17x8 with 4 1/2" BS and Mickey Thompson DR 275/40R17's out back
The front has 2" Hotchkis drop springs. The rear is stock mono leaf.
17 Intro Polished Twisted Vistas 17x7F & 17x8R BS 4.75F/5.25R
Yokohama AVS Sport Tires 235/45/07 & 255/40/17
Hotchkis TVS System 2" Front Drop/1.5" Rear Drop
Speedtech Tubular Upper/Lower A Arms
Here is my latest
American Racing TTO's 17x8
BFG's g-force KDW's 235/45 on the front
BFG's g-force KDW's 255/45 on the rear
billet specialties gtx 07
front 17/8 5 in bs 245/40/17
rear 17/9 1/2 5.5 bs 275/40/17
yokohama avs tires
no mini tubs and no tire rub
ARE hopsters 17 x 7. 4"bs with 235/45-17 (225's fit better but was not available) 17 x 9.5. 5.5" bs with 275/40-17
#2 · (Edited)
With the 275/40-17 on 17 x 9.5" with 5.5 bs I do get a slight rubbing on the top inside edge of rear drivers tire to inner wheel well when the axle is tilted/angled (going over speed bump at an angle, reversing down steep grade while turning etc...) My 12 bolt wheel mounting surface with discs is the exact same length as a factory 12 bolt with drums wheel mount surface.( rotors are just a little thicker then the drums so when I cut my ends off for pressed on bearings/moser axles I compensated for the added rotor thickness)
255/45-17 kumhos on 17 x 8 w/4.75bs
275/40-17 kumhos on 17 x 9.5 w 5.5bs
Maybe these pics will show more difference.
17 x 8 rear wheels with 4 3/4"bs 255's (drum brakes)
17 x 9.5 rear wheels with 5 1/2" bs 275's (disc brakes)
Weld Pro Stars
15x6 front w/225/60/15
15x8 rear w/255/60/15
backspacing is same as stock
front tires just barely rub the paint off the frame when you turn all the way to lock...never even noticed till I seen the paint rubbed off
Centerline Convo Pro's
fronts 15 X 7 with 225 - 50 X 15's
Rears 15 X 15 with 29 - 18.50 X 15 Mickey Thompsons
#3 · (Edited)
My wheels.
The spacing is 5 BS Front 17x8. 5.5 BS Rear 18x9.
I'm also using a different subframe to allow wider front wheels.
My new wheels and tires:
American racing 200S 15"x7"
Tires: Hankook 225/60-15 front and rear
Budnik fontana's
17x8 4-7/8 backspace on front and 17x11 5-1/2 backspace on rear. 245/45/17 and 315/35/17 bfg KDs . DSE mini tubbed
All DSE front end, coil over relocation, koni's, DSE UCA/LCA etc. Back is DSE 3" drop leaf w/offset shackle, so basically its lowered 3". No problem with front rubbing, I could pick it up another 1/2 inch but I like the stance.
#4 · (Edited)
Weld Prostars
15x5's front with 2.5"bs and 205/65/15's with no issues and disc brakes.
15x8's rear with 4.5"bs... 285's (McCreary's) rub inner wheelwell on turns and off camber bumps... 275's no issues.
275/60/15's
285's/60/15 SH
I've got 215/65/15 BFGs up front, and 255/60/15 BFGs out back. Stock Springs up front, 5 leaf multi-leaf setup out back from ricks camaro with competition engineering traction bars.
Centerline Sundance Retro - Purchased directly from Centerline
Yokohama S-Drive - Purchased from Tire Rack
Back 17x9.5 - 5.5BS - 275/40R17
Front 17x7.0 - 4.5BS - 235/45R17
235/60/15 15x7 rims front
255/60/15 15x8 rims back
Hotchkis suspension and lovin it.
#5 · (Edited)
All stock worn out suspension. MP Brakes 11" slotted/cross drilled discs up front and MP Brakes 11" drums out back. 16x8 4" back spacing AAR TTD wheels wrapped with BF Goodrich g-force 225/55/19 tires front & rear. The fronts rub on hard bumps.
225/70/14 Road Hugger Radial G/T (RWL) on 14x5.5" date coded steel rims
I also run a set of 15x8 4" back space Rallies and 15x7 4" back space rallies
255/60/15 on back and 225/60/15 on the front no rubbing problems.
Here is the old scool look :cool:
#6 · (Edited)
225/60/15 in front, 245/60/15 in back. Great fit--4.5 inch backspacing.
Coys Wheels (C-57)
Wheel Size: Front - 18x7 / Back - 20x8.5
Tire Size: Front - 235/40/R18 / Back - 255/35/R20
Clearance Issues: NONE I'm actually thinking about lowering the car an inch
15X8 rally's with 235-60-15 dunlop gt qualifiers.
I am thinking about going with a 15X7 in the front to put on a smaller tire like a 205 I am getting a little rub when I crank it all the way.
Finally, after subscribing to this thread FOREVER, I get to post pics of my new tires and wheels!!! :hurray:
Wheels are the brand new Voxx "Old School"
Front: 17 x 8 with 4.75 backspace on Hankook Sport K104 235/45/ZR17
Rear: 17 x 9.5 with 5.5 backspace on Hankook Sport K104 275/40/ZR17
Sizes:
Front: 15X7 with 4" bs and 215/65/R15
Rear: 15X8 with 4.5" bs and 245/60/R15
Style:
Wheels: Chrome corvette/camaro rallye wheels from Coker Tire with '67 caps.
Tires: BFG Radial T/A from Coker Tire
Modifications:
None, has original front suspension, rear monoleaf and 12 bolt rear.
Notes:
Thanks to everyone for the help in selecting tire sizes and backspacing! If I was to reorder I would do it exactly the same. Both front and back sit about 1/2+ inch inside the wheel lip. Coker gave great service and fast shipping. I will be ordering a set of redlines to go with my original steel wheels and covers soon.
You have insufficient privileges to reply here.
