Wheel decode - YZ - Team Camaro Tech
Tag Team De-coding tags and numbers.
Thread Tools Display Modes
Old Mar 15th, 09, 11:38 AM
drdave69 drdave69 is offline
Default Wheel decode - YZ
A friend of mine has 4 steel wheels with the code of YZ and all have a K-18-4 date. What were these originally used for?
Dave, member number 7704
2000 Dodge Viper GTS
Old Mar 15th, 09, 01:55 PM
wagonman's Avatar
wagonman wagonman is offline
john
Default Re: Wheel decode - YZ
Are you positive it has a YZ code?
GM Rally Wheels
XA 14X5 BS-3 1/2 67 Chevy II with drum brakes
DA 14X5 BS-3 7/8 67 Chevy II RALLY with disc brakes
DG 14X6 67 Camaro & Chevelle with discs brakes
XB 14X6BS -4 3/8 67 Chevelle SS, 68-69 Chevelle with F-70 Tires, 70 Chevelle
XN 14X6 BS-3 3/4 68-69 Camaro & Nova with drum brakes. Different shaped outer
AE 14X6 BS-4 3/8 70 Chevelle Station Wagon
XG 14X6 BS-3 7/8 68-69 Camaro with discs brakes, 68-70 Chevy II/ Nova with disc brakes, 69-69 El Camino without disc brakes. Wider drop center than normal
DE 14X6 BS-4 3/8 71-72 Nova & Chevelle, 6 hole wheels
YW 14X6 BS-4 3/8 Exactly like XB, may have come on same cars
YJ 14X7 BS-4 3/8 69 Camaro/ Chevy II L72- ZL1, 70 Nova
AV 14X7 70-72 Camaro, 71-72 Nova, 6 hole wheel
XT 14X7 L72- ZL1 Non Rally Wheel
YA 14X7 BS-4 3/8 69 Chevelle SS Wheel
AO 14X7 BS-4 3/8 70 Camaro &69 Chevelle SS Wheel
DB 15X5 67 Passenger Cars with disc brakes.
DF 15X6 BS-4 1/16 67-68 Camaro Z28
DC (BIG) 15X6 B-3 1/2 67 Corvette, No other stampings on rim
DC 15X6 BS-3 1/2 68-70 Passenger car, 67 Passenger car (early models)
FI 15X6 BS-3 1/2 68-70 Passenger car, 67 Passenger car (later models) Riveted instead of welded together
YS 15X6 BS-3 1/2 68-70 El Camino
FW 15X7 BS-4 1/4 71-up most any GM
AG 15X7 BS-3 3/4 68 Corvette (will take 15x8 Beauty rings)
YH 15X7 BS-4 1/4 L72- ZL1 Z28 Rally 69 narrow drop center
AD 15X7 BS-4 1/4 L72- ZL1 Z28 Rally 68 wide drop center
AV 15X7 70, 71, 73 CAMARO Z28 5 spoke wheel
AZ 15X8 BS-4 69-82 Corvette
Here are a few extra notes:
*BS-Backspacing
* All the rally wheels made in 1967 have big marking letters, no date code, a little bit different shaped center and slightly bigger holes in the center.
* The 15x7 beauty ring will go on all the 15x6 wheels.
* All the hubcaps interchange with each other.
Remember,I'm not making this stuff up!
1969 rs/ss 396 350hp/4spd conv a/c,pw,ps,foldown
1968 Z/28 crossram- j/l8 conv pw,ps,foldown
1963 nova ss 350/4spd conv a/c,ps,pt
1963 nova 400 4dr 6cyl/700r4 a/c
2006 GT/5spd mustang conv
Old Mar 15th, 09, 04:49 PM
Yes, they are YZ steel wheels, not Rally wheels.
Old Mar 15th, 09, 10:34 PM
wagonman's Avatar
john
OOK,
I know nothing about steel wheels.....
Old Mar 16th, 09, 05:48 PM
gro51 gro51 is offline
Joe
I thought I could find you an answer here: http://www.camaros.org/suspen.shtml#Wheels
but I don't see a "YZ" listed. Again, are you sure it's "YZ" ?
Joe
'68 SS/RS 350
Never enough time... even less money.
http://www.eastcoastcamaroclub.com/
Old Mar 17th, 09, 05:13 AM
Yep, all 4 wheels are YZ. He got them with a 1963 Corvette, not a Camaro.
Old Mar 17th, 09, 11:40 AM
Vintage 68's Avatar
John
Wink Re: Wheel decode - YZ
Can't be a '63~64 wheel, GM/Kelsey-Hayes didn't code wheels this way until after 1965
YZ is a 1969 Full Size 15 X 6 standard steel wheel.
The code is not quite complete, but the Month of production date is the number on the same side as the 'YZ'...
The 'K' is Kelsey-Hayes, the first number after the 'K-' is the plant it was made in. So if that '1' is correct, then it is Romulus, MI.
The '8' may be the year manufactured - or 1968.
Sometimes the numbers are very litely stamped or painted over making them hard to see.
Would have to know all numbers or see a good a picture to decode for sure.
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Mar 17th, 09, 08:17 PM
NHBandit's Avatar
NHBandit NHBandit is offline
Mark
John do you have a website you found that lists all the wheel codes you could share with the rest of us or is your info from a book ? I'm sure alot of us have plain steel whels we'd like to be able to ID.
Old Mar 18th, 09, 04:57 AM
I'll try to grab one the next time I am near his house so that I can get photos.
Old Mar 18th, 10, 08:21 AM
The Sleeper 327 The Sleeper 327 is offline
Broc
GM Rally Wheels
*BS-Backspacing
how can you tell the difference on DC coded rally wheels?
1968 Camaro SS 350
--350, muncie 4spd, 12 bolt 3.31 (multi-leaf)
1967 Camaro (plain jane)
--350, muncie 4spd, 12 bolt 3.31 (mono-leaf)
1965 Chevelle Malibu SS 327
--327, powerglide, 12 bolt
  #11
Old Mar 18th, 10, 12:28 PM
Vintage 68's Avatar
John
Thumbs up Re: Wheel decode - YZ
I don't have a 'book' ... I've got a Binder
I use lots of sources for my cross-references, most common of which is the GM 1975 Master Cat. with wheel part numbers and codes.
I also have several hand typed lists from data I've gathered over the years from several sources.
It was always interesting to me the number of different wheel combo's - the different manufactures and wheel designs/profiles available for most vehicles from the factory. Plus, I was always looking for certain wheels for my cars over the years - paid to know which ones I wanted ...
There are several pretty good published sources for some the same info.
I'd start with something like Alan Colvin's "Numbers" books, then look to some of the "Interchange" books by Paul Herd and finally some of the specialty publications for Camaros of given years or generations by MacNeish, Hooper and the others.
And if think it's hard to find good info on Chevy rims - you should try find decodes for BOP/GMC stuff
(edit) WOW ... I just noticed this post is a YEAR old !!!
No wonder I couldn't remember typing this yesterday ...
1968 Convertible
Some trucks
  #12
Old Mar 18th, 10, 08:10 PM
Broc
Yea......I found this thread by googling "DC rally wheels"...just cleaned up my rally wheels and found the DC code on them....no other markings outside of KH (kelsey hayes?) and GM (general motors) on the inside part of the rally wheel.......and 15x6 on the inside part of the rim where the tire covers it. I am assuming they are 67 vette rally wheels then from the information I have found.....
1968 Camaro SS 350
  #13
Old Mar 21st, 10, 01:58 PM
68camaroz28 68camaroz28 is offline
Chick
Yep, good assumption. Large stamped DC coded rally wheels with no date stamp were correct 15X6 67 Corvette rally wheels. Used same trim rings as later used on 15X7 z28 rally wheels. Service replacement DC wheels had a smaller size DC stamping with a date code which started in 68. Original non date coded DC rallys bring decent $ if in nice condition but nothing like DF coded wheels, etc....
Chick
68Z28-Orig. Engine/Drivetrain
69Z28-Orig Eng & GM Cross-Ram Pro-Tour
69 Nova L34 Father/Son
69 Nova L78 Surv purch-new
2015 Z28 Our 68Z Restoration http://www.camaros.net/forums/showthread.php?t=182584
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Tag Team      Current Topic: Wheel decode - YZ
Location
Location
First Name
Human Verification
