Tools & Shops Shop Rat HQ
Old Mar 20th, 09, 08:40 AM
MissionCritical MissionCritical is offline
Team Member
Default How to get my new air compressor off the pallet
I was hoping someone else has purchased a large air compressor and found an easy (or hard) but safe way to get the compressor off of the pallet that it arrives on.
I got a 7.5 HP IR, which arrived bolted to a standard pallet. I think it weighs about 700-800 lbs. I used a tractor to get it into the garage, but had to manually get it over to where its going to get installed, as the tractor won't fit in my garage. So far, I've managed to unbolt it from the pallet, and I used large furniture clamps to pull it to the edge of the pallet. My plan was to get one of the legs off the edge of the pallet onto a block, then try to remove the pallet from the rear legs by (somehow) sliding it out backwards and transition the rear two compressor legs onto blocks. My blocks have a couple of layers, so then I would remove one layer leg-by-leg, effectively then putting it on ground level.
This compressor is extremely top-heavy, so its easy to see how things could go very wrong. If one leg were to slip, down it would go I think.
Anybody else done this ?
-Kevin
'68 RS Camaro, 454 SBC
'69 Camaro, body only
Old Mar 20th, 09, 09:14 AM
DjD's Avatar
DjD DjD is offline
Administrator
Dennis
Default Re: How to get my new air compressor off the pallet
I have a 60 gal compressor I bought used that was still bolted to the pallet. I left it that way as it makes a good isolator between the floor and the compressor. Since I didn't want to bolt it to the floor I rigged up earthquake straps like those used on water heaters to secure it from tipping over. I'm really glad I left mine on the pallet, it makes the moisture drain easier to get at...
You can use tie downs around the tank hooked to lag bolts into wall studs to keep the unit from falling over as you jimmy it off the pallet. Play it safe and have a buddy or neighbor come over for a beer and to give you a hand to make it much easier to wrestle with...
...Dennis
White Wonder
The Nova
Photo Album
www.camaroslimited.com
Old Mar 20th, 09, 09:28 AM
Team Member
Thanks; I thought about leaving it on the pallet, but the location makes that bad. I could cut it down, but structurally, it might not be good and even the minimum size is too big.
But I like your idea of strapping it to something. Its near a wall now with steel supports, so that would provide another margin of safety. I had not thought of that and its why I asked before going further. I paid extra for the automatic drain thingie, which is good except they preinstall it and it makes for something else to make it harder to get off the pallet.
What I need is a good 'skyhook'...
-Kevin
Old Mar 20th, 09, 09:53 AM
prostreet69camaro's Avatar
prostreet69camaro prostreet69camaro is online now
Mike
Where in Texas are you located??? Update your profile with your city so we know where your at....
Mike
69 Camaro Prostreet - purple w/ghost flames , 502 w/ 871 blower
http://s268.photobucket.com/albums/j...treet69camaro/
Old Mar 20th, 09, 09:56 AM
clwilcox33's Avatar
clwilcox33 clwilcox33 is offline
Christropher
As Mike said, ya might get some offers of help if we knew where ya where at.
Christropher
1967 RS/SS 350...in pieces still.
http://www.67rs-ss.com/
**How to attach images**
MrDanB - "Don't worry about Mr.Wilcox...He has that incurable disease of thinking that they only made the Camaro in '67 "
Old Mar 20th, 09, 09:57 AM
DjD's Avatar
DjD DjD is offline
Administrator
Dennis
You could get a comealong like this...
Years ago I built a rope and pully sling for removing a camper shell from my truck and storing up under the rafters so I could park under it. You could improvise something with pullys to spread the weight out across several roof joists if you feel the compressor is too heavy to lift off of just one.
...Dennis
White Wonder
The Nova
Photo Album
Old Mar 20th, 09, 10:26 AM
Team Member
I have one of those and have added that to my plan. There is a beam right above the compressor and I am attaching my come-a-long and probably two heavy tie-downs. That way, it won't be able to fall over, at least in theory. But my roof support can probably only take about 300 lbs, but at least that solves my main problem: how to keep from ruining my new compressor when it falls over and squashes someone.
Profile updated: I'm near San Antonio.
-Kevin
Old Mar 20th, 09, 02:07 PM
rojo rojo is offline
Robert
Add some temporary 2x4 or 4x4 supports from the exposed beam down to the floor. Hoist it up with the come-along slide out the pallet.
Robert
'69 355ci 10:1, 64cc Edelbrocks, Comp Mag 280H, Performer RPM, 700r4 (2000 stall), 3.55 posi A/C PS PDB Hotchkis
'67 369ci 10.3:1, 64cc Edelbrocks, Voodoo 276/284, Performer RPM, Holley 650DP ...4spd 3.73 Moser 12 bolt
TC member #18
Old Mar 20th, 09, 05:31 PM
dyno jonn dyno jonn is online now
Jon
How about using an engine hoist ?
Jon N.
At the back of the Daylight Saving scheme I detect the bony, blue-fingered hand of Puritanism, eager to push people into bed earlier, and get them up earlier, to make them healthy, wealthy and wise, in spite of themselves." Robertson Davies
Old Mar 20th, 09, 06:23 PM
DUSK BLUE DUSK BLUE is offline
Mike
I'm for the hoist, I used one to assemble a 4 post heavy lift.
1969 Camaro Convert. 355 ,4speed, 12 Bolt,3.73 rear, Dusk Blue Code 51
1979 Z28 auto,all stock,Red,Tan Int.
http://longislandmusclecars.zoomshar...01969%20CAMARO
Old Mar 20th, 09, 09:58 PM
Team Member
I thought of using my engine hoist, but it does not have enough 'up' lift. I would need at least about 7'. A bobcat would probably work, but I don't have one handy, and it would leave black marks on my floor.
Right now, I have the roof supported on a 4" pipe. I made a loop over the top of the compressor to an eye-bolt to the roof 'rafter' connect to my come-a-long but my metal garage framing is not strong enough to support more than about 300-400 lbs. So my entire setup is only to be used in case something goes wrong with getting it off the pallet. And even then, it won't hold the weight.
One problem with the IR compressor, is that they don't provide any lifting points at all, and creating one is very difficult.
My best plan right now is to support each of the three pads on the compressor from under the pallet, then cut the $%#$@#$ pallet away, and gradually reduce the height on my shims until I'm at ground level. Seems safe enough...If you don't hear how it went, then I guess it went badly...
-Kevin
Old Mar 20th, 09, 10:22 PM
Jon
Well, professionals that set huge presses use ice. It just melts away and leaves them on the floor.
Jon N.
Old Mar 20th, 09, 10:25 PM
Vegas69 Vegas69 is online now
Todd
Redneck all the way...tie a rope to the pallet and floor your truck. I bet the pallet pops right out. Just make sure you put it right where you want it first. Seriously how about building a gradual ramp and pulling it off with some power. Or just a few tough guys.
Old Mar 21st, 09, 09:34 PM
jr68's Avatar
jr68 jr68 is offline
Team Member
Jerry
Use a 4x4 or bigger to span 2 or more of your trusses then hang your come along to that. It will distribute the weight so you don't just stress the one truss.
Old Mar 21st, 09, 10:21 PM
Arai Arai is offline
Team Member
Chris
Humm....I have a 60 gallon. I left the pallet on mine as well for extra stability and vibration control. Mine was loaded in the back of my truck and I had to unload it by myself. I ended up lowering in on it's side, backed my truck in the ditch by my driveway, and slid it off the tail gate and then stood it upright. There I just had to "shimmy" it into the garage.
Seems like your plan of attack would be the best with eliminating a layer of the block at a time. Keep us in the loop how it goes.
Chris
-69 Camaro- X11
http://www.my69camaro.net
Follow my build here:
