Body Shop Paint & Body Forum
Old Mar 28th, 09, 06:32 PM
fatbaby fatbaby is offline
Bobby Pearce
Default 1969 Camaro Inner Fender Removal
Need to remove the inner fenders and install new aftermarket replacements. Can I get the old inner fenders off with the engine and headers in the car?
Thanks for your advice and time!
Bobby
Old Mar 28th, 09, 06:59 PM
69CamaroRT 69CamaroRT is offline
Robert
Default Re: 1969 Camaro Inner Fender Removal
yes, but its more difficult. its easier to take the fender off
69 Camaro Z/28 RS 10A of 68. 50 S with 723 int. 406 ci. 350TH. BU 12 bolt posi. http://s190.photobucket.com/albums/z...view=slideshow
Old Mar 28th, 09, 07:20 PM
JimM JimM is offline
Jim
They will come off. It's neither fun nor easy. You have to "roll" them out, grab the inner bottom and pull, they will come out upside down.
Getting them back in is really fun.
former TC moderator, who really hope nobody here thinks I paid for or asked for this lifetime gold membership
Old Mar 30th, 09, 06:58 AM
Eye69 Eye69 is offline
I took off my front end..still a pain in the &*&, I would try to roll it out first. One of those projects I hope to never have to repeat, but am glad I did it. Also used new hardware. Only had to redrill 2 holes that were off a little bit. Dont forget to sand, prime and paint the new inner fender before you install.
Old Mar 30th, 09, 07:34 AM
RickD RickD is offline
I think the assembly manual recommends removing fender and inner as a unit. I did it separately and it wasn't pretty.
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings!
Old Mar 30th, 09, 01:01 PM
chuckboy7 chuckboy7 is offline
Jeoffery J
I too am interested in this topic. Guys when removing the fender should you drill an alignment hole for reinstaling the fenders? My sheet metal is nice and straight I would hate to screw that up.
Jeoff J.
Buffalo , NY...Brrrr
MY RIDE: http://community.webshots.com/user/yukongt
project "semi precious metal"
Old May 13th, 09, 10:06 AM
Clean Cut Creations Clean Cut Creations is offline
Tech Team
JOHN
No need for the alignment holes. Just keep track of which shims go where on the fenders and put the fenders/bolts back in the "dirt shadows" and the alignment should be the same on reassembly. The trick with these fenders is to align the door to fender gap first with the bolts loose or removed at the core support. When the fender to door gap is where you want it, then install the header panel and gap the fenders at the front. Keep core to fender bolts installed but loose at this time. Install the hood with the latch removed and adjust. Install the cowl screen and adjust. when you like the gaps all around tighten all bolts. Install hood latch and check for fit.
We are currently booking restorations for this season. Contact the shop for details. http://WWW.CLEANCUTCREATIONS.COM
