Tools & Shops Shop Rat HQ
Old Apr 1st, 09, 07:50 PM
ironhorse78247 ironhorse78247 is offline
Tech Team
Default Nutsert Tool
Does anyone on here know where I could pick up a Nutsert installation tool?
68 Coupe, 350, M20 frame off restoration (a work in progress).
Old Apr 1st, 09, 07:52 PM
kcart55 kcart55 is offline
Team Member
Kevin
Default Re: Nutsert Tool
http://www.imperialinc.com/items.asp?item=0068850
Old Apr 1st, 09, 09:34 PM
yellow69RS's Avatar
yellow69RS yellow69RS is offline
Jeff
Harbor Freight Tools has them as does Menard's. I know there are no Menard's in Texas but perhaps Lowes.
Jeff
Old Apr 2nd, 09, 05:23 AM
Lucky68's Avatar
Lucky68 Lucky68 is offline
Mike
I picked up one from Homepro Fasteners on Ebay. It's around 100 bucks as a kit but worth it. I've actually used the tool more than I thought I would.
http://cgi.ebay.com/ebaymotors/RIVNU...spagenameZWDVW
68 Camaro: No motor/trans, 12 Bolt Posi 3.73, Hotchkis/Global West suspension, Vintage Air.
http://rides.webshots.com/album/250023748XWhfQW
Old Apr 2nd, 09, 06:48 AM
JimM JimM is offline
Jim
I bought mine at Menards, use it a lot.
68 SS (clone) Vert, #'s matching 383, TKO500, Holley EFI
04 Silverado SS The Black Beast
93 Polo Green Corvette
http://www.Jimragtop.com
Jim's NEW Blog!
Jim Cam
Old Apr 2nd, 09, 07:36 AM
yellow69RS's Avatar
Jeff
And for a lot less than a hunert bucks I'll bet.
Jeff
Old Apr 2nd, 09, 08:38 AM
paulm paulm is offline
Paul
There's actually a tool for that?!?! Damn it, and here I've been using an Allen wrench, bolt, couple of nuts and lock washers.
My 67 HSR Intaked RS Coupe
Best of 1.56 - 11.69@112.95
Old Apr 3rd, 09, 06:29 PM
Lucky68's Avatar
Mike
Jeff
I bought the menard's tool before the homepro kit. I wasn't impressed with it so I took it back. It all depends on if you want a tool to get the job done or one that works good. You get what you pay for.
Old Apr 9th, 09, 11:27 PM
CamarosRus CamarosRus is offline
Chuck
do a google search for the hand operated tool that MARSON mfg...........
I already had their pop rivet tol and am converting it over to the rivet nut tool............
I then bought 100 1/4x20 riv nuts on line from HANSEN rivet company in Calif for $18.00+ plus FedEx Freight.....
I'm going to be installing rivnuts into certain walls on my P.U. truck bed to fasten aluminum tie down track for securing loads with...........
Chuck Sharin
Seattle area
69 COPO recreation (Day 2)
70 Z-28
70 L-78
70 SS R/S
73 RS LT
Old Apr 10th, 09, 09:20 AM
prostreet69camaro's Avatar
prostreet69camaro prostreet69camaro is offline
Mike
I hope your loads arent very heavy. I would not trust a nutsert for very much pressure load. They will probably just pull out.
Mike
69 Camaro Prostreet - purple w/ghost flames , 502 w/ 871 blower
http://s268.photobucket.com/albums/j...treet69camaro/
