Car Hard to Start After it gets hot??? - Team Camaro Tech
Thread Tools Display Modes
Old Apr 6th, 09, 05:31 AM
mtdubvee1 mtdubvee1 is offline
Tech Team
Default Car Hard to Start After it gets hot???
Hey guys I have another problem. I just finished building my 68 so I'm finding out all the kinks right now.
Question: When the car is cold it starts fine, but after it gets warm and I shut it off, it seems like the starter drags and doesnt want to start. But after it cools down it fires up easily? Something with the starter getting hot maybe??
Any input or suggestions would be greatly appreciated.
Old Apr 6th, 09, 06:00 AM
1969 RS/SS DROPTOP 1969 RS/SS DROPTOP is offline
Paul
Default Re: Car Hard to Start After it gets hot???
Yep sounds like the starter needs rebuilding or replaced.
Old Apr 6th, 09, 06:30 AM
Everett#2390's Avatar
<Jake-68's rule
Or battery cables of a larger gauge. Ground cable on the engine should be on the block rather than the cyl head, if alum.
Old Apr 6th, 09, 06:36 AM
lluciano77 lluciano77 is offline
I added a Ford relay and shorted out the starter. It is easy to do and eliminates hot start problems. The Ford relay is about $15. Your starter is probably fine. The Ford conversion will take a lot of load of the starter anyway.
Here is a link on the conversion.
http://www.oldengine.org/unfaq/solenoid.htm
Old Apr 6th, 09, 07:42 AM
captcanuck68 captcanuck68 is offline
Ted
While you're at it...check out the coil.
capt
Bumper sticker- I'm not SPEEDING
I'm QUALIFYING!
Old Apr 6th, 09, 08:30 AM
yellow69RS's Avatar
yellow69RS yellow69RS is offline
Jeff
How and why this Ford solenoid works is beyond me..... you still have to "pull in" the GM one in order to get the drive to engage the flywheel unlike the Ford starter that uses the magnetic pull of the field coils to engage it. I'm voting with the guy that says the starter needs rebuilt.
Jeff
Old Apr 6th, 09, 03:28 PM
james7773 james7773 is offline
James
Are you running headers? Perhaps your just getting a "heat soak" on the starter motor.
My 67 RS 327...its a work in progress.
http://www.camaros.net/showroom/data/500/2.jpg
Old Apr 6th, 09, 04:03 PM
hallysport hallysport is offline
harold grier
try a heat shield over the solenoid.
Old Apr 6th, 09, 04:51 PM
Chevy-SS Chevy-SS is offline
Dave
I agree that it's probably a starter issue. I also like the suggestion about"heat soak", especially if you've got headers that are routed close to the starter.
You could try a heat shield, or perhaps wrap the headers in the area that's close to the starter.
Dave F. in Rhode Island
'68 Camaro SS Accel DFI 454 (SOLD - I'm a boring Corvette owner now)
Bought my first big-block Chevy in 1970
Old Apr 6th, 09, 05:08 PM
1969ProStreetCamaro 1969ProStreetCamaro is offline
David
........added the remote stater solenoid also, no hot start problems as well.
David F.
"All I need is a fast machine". Steve McQueen
My Machine: 1969 Pro Street Camaro
468 CID 661 Horsepower Turbo 400
33"x19.50" Mickey Thompsons
Check Out My Camaro
661 Horsepower 468
  #11
Old Apr 6th, 09, 05:41 PM
novaderrik novaderrik is offline
Jeff
it works becasue instead of using the small power wire that goes thru the ignition switch to kick the solenoid out, it uses the full battery power straight from thr + battery terminal to do it instead of the reduced voltage and amperage from all the losses from the battery, thru the firewall, thru the switch, back out thru the firewall, and out to the solenoid..
but this will only affect the way the solenoid kicks out- it won't help if the actual starter "drags" when hot. then you need a stronger starter motor.
but before throwing a starter and solenoid at it or converting to the Ford solenoid, i'd look at the battery cables, battery, and all connections. just adding bigger battery cables and making sure they have clean and solid connections can help a lot.
you don't plan sincerity.
you have to make it up on the spot.
wanna hear about 20 years ago when i was too smart to know any better?
  #12
Old Apr 7th, 09, 09:37 AM
Paul
As i stated above bro have your starter rebuilt or go buy a new one. More than likely your starter is old/used and has been hot many times before and is now dragging when it gets hot resulting in hard/dragging starts.
  #13
Old Apr 7th, 09, 05:01 PM
68427 68427 is offline
My 427 was hard to start when warm. I replaced the starter & still had issues. I added a relay as well. Problem solved.
http://www.madelectrical.com/electri...evymain1.shtml
  #14
Old Apr 11th, 09, 08:43 PM
Tech Team
I'm hooking up a ford solenoid as we speak. Ill let you gus know the outcome. If it doesnt work Im gonna try some heat warp. Should know tomorrow sometime.
  #15
Old Apr 11th, 09, 09:56 PM
Yellow69RSZ Yellow69RSZ is offline
Al
Check your timing, make sure the headers are not heating the starter up too much, and check the CCA on the battery, I like at least 850, lots of cheapo batteries on the market with wimpy CCA's.
Mostly Camaros and Chevelles
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Car Hard to Start After it gets hot???
Location
Location
First Name
Human Verification
