Gopher Erradication - Team Camaro Tech
Bench Racing Stories, cruising and more.
Old Apr 8th, 09, 12:09 PM
alanrw alanrw is offline
Alan
Default Gopher Erradication
OK, saw the post on carpenter bees and was impressed. I have a gopher that is starting to irritate me. In the past, the smoke bombs have done the trick. I think this one has his own gas mask and is impervious to poisoned bait.
What's your tried and true method for getting rid of them? I was thinking about hooking up the pool vacuum hose to the exhaust pipe and letting the car idle for a half hour or so.
alan
Old Apr 8th, 09, 12:13 PM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Default Re: Gopher Erradication
any other homes near you? If not, 22 caliber works
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r
Photos for viewing
Learn How To Post Pics here
Old Apr 8th, 09, 12:36 PM
Badbird's Avatar
Badbird Badbird is offline
Banned
Ron
Just call Bill Murray man!....He'll git rid of it for you, right?
Old Apr 8th, 09, 12:39 PM
Alan
So I have to coax him out of his hole with music and then grab him?
.22's would just bring SWAT to my neighborhood after a 911 call "Shots fired" and the resulting paperwork would take too long!!
But for argument sake, what time of day is best? I could probably get away with a pellet gun.
alan
Old Apr 8th, 09, 12:53 PM
nashcar nashcar is offline
Steve
I was going to say a case of beer and a friend with a .223 but you're not secluded enough. Best time of day is early morning.
1969 Z28
http://www.byjanmarie.com/camaro/Z28.html
1969 Firebird 400 one owner.!
http://www.byjanmarie.com/firebird/69.html
My new project for 2010 DONE!
http://www.byjanmarie.com/camaro/69camaro.html
2002 Camaro SS LE/SLP
Old Apr 8th, 09, 01:13 PM
paulm paulm is offline
Paul
In the past I've used this stuff called "Gopher go" and it worked ok but then a couple of outdoor cats started hanging around the house and they seem to like to kill gophers.
We have one in the backyard now that the cats haven't killed yet, in searching the web I though this would be a fun idea:
Use your vehicle's exhaust to flood the gopher tunnel network with carbon monoxide. Find a way to couple your exhaust pipe to one end of a garden hose, and put the other end of the garden hose in a tunnel. Make sure that you cover any open holes with dirt to keep as much of the exhaust from leaking to the surface as possible. Let your vehicle idle for 15 - 30 minutes to flood the entire tunnel network. Repeat as necessary.
Best of 1.55 - 11.57@114.33
Old Apr 8th, 09, 01:18 PM
Alan
Would the resultant backpressure burn a valve? And to be perfectly honest, the '69 Camaro would be the car of choice as it puts out a lot more stuff than the 2002 PT Cruiser!!!!
alan
Old Apr 8th, 09, 01:39 PM
Everett#2390's Avatar
<Jake 68's Rule
No backpressure so to speak at idle, not enough heat. Three-fourths diameter hose would be fine.
I hear ya on doing a little .22 practice. would love to do it to a muskrat(s) in my canal/pond.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Apr 8th, 09, 01:54 PM
Vintage 68's Avatar
John
Thumbs up Re: Gopher Erradication
I use regular old "Road-Flares" (or Fussies to the law enforcement crowd )
Light it ('strike end while holding away from body' ) and stick it down on of their fresh early morning holes - watch for where smoke comes out of ground and go put them there also - you can stomp the little ba$tards as they exit the ground, all groggy and hung-over, or just apply a decent shovel 'wack' to them and they will be trash ready in no time...
They do sell fancy, new-fangled and expensive "Gopher-Gassers" at most home stores - but, they are just small road-flares
Evidently gophers are deadly affraid of flares or just love to come out to see where the accident was...
There is a guy out this way with a 'service' for local farmers that pumps a propane-oxgen mix into the burrows and then ignites it.
I've heard that deaf gophers come streaming out of the holes (little ears bleeding and all...) and then expire quite quickly right after the "boom"
I'll try to find the article from the paper a few year ago...
(edit) (edit again - oops, Zuma beat me to the link ) Wouldn’t you know it – the company was called RODENATOR – somewhere our ‘Governator’ is chuckling - http://www.gophernator.com/ -
found another reference to blasting them here - http://www.garden-counselor-lawn-car...r-blaster.html
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Apr 8th, 09, 01:55 PM
Paul
Heck ya, you could even tweak the carb/timing and make it run like crap to dump lots of toxic gas!! Personally I would probably use a flexible hose like dryer hose but smaller diameter.
Hmm...I wonder if you could make it run rich enough so that you could light the exhaust gas in the tunnels on fire...how cool would that be?!?!? Blow them little SOB's into the neighbors yard!!!
Old Apr 8th, 09, 02:00 PM
davidpozzi davidpozzi is offline
David Pozzi
Get a Macabe gopher trap, attach a chain to a 16" long piece of wood about 1" diameter. The wood stake must be driven in the ground to prevent your neighbors cat from running off with the gopher and your trap. I lost one last week even though I had the stake in the ground.
I bait the trap with lawn grass or lettuce and it works great. Other brands of traps are harder to set, the Macabe is pretty easy.
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com
67 RS 327 original owner. 1965 Lola T-70
Old Apr 8th, 09, 02:09 PM
zuma's Avatar
zuma zuma is offline
Mike, 69's rule
John, It is one of these?
(STAY THIRSTY, MY FRIENDS).
1969 Camaro
1990 IROCZ28 convertible
2004 Silverado Z71 4x4
1981 Mazda RX-7
GGSMU member
http://www.ggsmu.com/
Old Apr 8th, 09, 02:15 PM
Vintage 68's Avatar
John
Talking Re: Gopher Erradication
YouTube - Rodenator Pro, bunker buster
- THAT"S IT
Something tells me there is gonna be a 'swarm of "micro-quakes"' in my area this weekend
1968 Convertible
Some trucks
Old Apr 8th, 09, 02:21 PM
Alan
That is absolutely hysterical. I guess I could use propane gas from my Bernzomatic plumbing torch kit. Now I just have to figure out how to remote ignite it as I am fond of my eyebrows. Hmmmm, what about a spark plug, coil and a 12V battery?
alan
Old Apr 8th, 09, 02:33 PM
Paul
You guys are AWESOME!!!!!!! I gotta have one of them 'Rodenators"...prolly blow up the house or something though. Maybe I should just try the road flares instead...
