Tools & Shops Shop Rat HQ
Old Apr 13th, 09, 10:29 AM
Gambitt's Avatar
Gambitt Gambitt is offline
Team Member
Jason
Default Concrete floor coatings...what to buy?
I finished the outside of my garage last year, now I am going to trying to finish the inside of it up this year. I have been agonizing over a floor coating. I want something that is chemical resistant, but that doesn't cost 3-4 thousand. Keep in mind I am covering 1560 sq ft. What are my options? I can get a clear coat sealer from this place: http://www.convergentconcrete.com/main/main.html
that is fuel resistant for $800. What have the rest of your guys done? Thanks.
My Car (69 RS/Z28)
Gambitt
Old Apr 13th, 09, 11:14 AM
hirpms hirpms is offline
Team Member
Chris
Default Re: Concrete floor coatings...what to buy?
I just did mine. Epoxy coat! Look it up on line. You could do it for around 800 to 1000.
It is not water based. Prep is the main thing. Is your floor coated or sealed? If it is, you will have to grind it, or have it blasted. You will love it when its done.
Chris
Old Apr 13th, 09, 12:33 PM
Gambitt's Avatar
Team Member
Jason
I have read about epoxies, polyasparatics, etc. My floor was poured about a year and a half ago, but it has not been used yet. It is just bare clean concrete. I would either have to shot blast it or chemically etch it. I am checking the price on some epoxy now, but I am not sure it will be within budget. I understand that with epoxies you want 100% solids that is solvent based, not water based.
My Car (69 RS/Z28)
Gambitt
Old Apr 13th, 09, 01:19 PM
Team Member
Chris
Gambit! All you have to do is acid wash it. This etches it. Then apply the coating. You have it made. Its easy! It levels itself.
Chris
Team Member
Chris
Sorry ! Jason!
Old Apr 13th, 09, 02:50 PM
DOUG G's Avatar
DOUG G DOUG G is online now
I used the quick create<sp>brand Epoxy coating from Lowe's. 2 kits did my 24x24 garage, I think it was $65 or so per kit.(kit included acid for etching,epoxy paint,activator,and colored flakes)
I soaked a paint stick that I used to mix the paint in brake kleen for 6 hrs.... never softened, and everything has wiped up so far.
Doug G.-406ci
Camaro Pics ~ AKA: RedЯum
1.643 - 60'
7.511 @ 91.33 -660'
11.823 @ 113.52 -1320'
Old Apr 13th, 09, 03:50 PM
69Z28-RS 69Z28-RS is offline
Gary
I used Valspar Epoxy Concrete Coating... I think I paid less than $50/gallon kit thru Lowes about 6 yrs ago. The KEY is to clean/etch... and then dry well... before coating. I did those steps twice on new concrete. It's still good after 6 years; it hasn't come up, it hasn't suffered hot tire pickup... and it cleans up so easily.... (but is slippery when wet!)
Gary
69Z28-RS
Corvettes (5), Nomads (2), El Camino, etc
Old Apr 13th, 09, 04:32 PM
Gambitt's Avatar
Team Member
Jason
Since I am doing such a large amount of floor I hate to take a chance with one of the water based cheaper epoxies, I want to do this once and not have to worry about it. If I could buy epoxy locally I would be much more inclined to use it, but if I have to pay shipping it really gets expensive fast. I have read that Devoe paints make a good epoxy at a reasonable price, but there isn't anyone around me that sells that brand. I only live about 90 miles from Nashville, TN and I haven't even found any place there where I can buy epoxy...there might be one, but I haven't found it yet.
My Car (69 RS/Z28)
Gambitt
Old Apr 13th, 09, 05:26 PM
rs69ss rs69ss is offline
ED
i used Benjamen Moore epoxy and the clear you had listed in originally post very happy. Can be tinted to any color. I also put multi color chips on color then cleared it. After it set a couple days i put a couple coats of floor wax on it to keep overspray and drips from sticking to floor. Don't use any stronger etch than necessary because it will remove portland cement leaving a porus surface with will decrease your coverage of epoxy.
Old Apr 13th, 09, 05:42 PM
RamAirDave RamAirDave is offline
Team Member
Dave
We laid down 5000' of this in February:
http://www.anchorpaint.com/proddetail.asp?w=i&id=81
Good stuff. We have it at another shop that's held up well after about 10 years. And if you get pissed off at a pipe wrench and decide to throw it down from 15' up, it won't hurt it
Driving a #s-matching Z in the rain..... and lovin' it....
TheMuscleCarGuys.com
"Build them how the designers and engineers envisioned them to be."
Old Apr 13th, 09, 05:57 PM
Gambitt's Avatar
Team Member
Jason
Dave,
That looks like some pretty good stuff. While it is not 100% solids, it still looks like it has decent specs. I wish I had a local distributor around me.
My Car (69 RS/Z28)
Gambitt
Old Apr 13th, 09, 06:05 PM
Team Member
Dave
One coat covered well. 2nd coat would be even better, but we had no interest in doing that twice.
Says there are over 20 independent dealers in addition to their own, but doesn't show a list of those.
Old Apr 13th, 09, 07:43 PM
yellow69RS's Avatar
yellow69RS yellow69RS is offline
Jeff
I used a product called Supercoat from Orleans Enterprises on my basement floor. I don't recommend it at all. I saw it advertised in a woodworking magazine and fell for the sales pitch on the phone. PM me if you need all the details.
Jeff
Old Apr 13th, 09, 08:04 PM
Havin' Fun's Avatar
Havin' Fun Havin' Fun is offline
Tim
Some good reading on the subject.... Check out the "sticky" threads
http://www.garagejournal.com/forum/f...splay.php?f=20
Old Apr 13th, 09, 08:30 PM
Gambitt's Avatar
Team Member
Jason
Thanks Tim, I read on the garage journal quite often, that is where I have got most of my information on the subject.
I guess I just live in a really bad area to try and find anything that can be purchased locally.
My Car (69 RS/Z28)
Gambitt
