Tools & Shops Shop Rat HQ
Old Apr 19th, 09, 08:38 AM
Mat Klemp Mat Klemp is offline
Team Member
Default Differential Gear Lube Filler
Last time I filled the differential I spilled a lot of oil trying to fit the bottle up into position etc. I made this to fill it with a soda bottle, the cap from the lube bottle, hose and a basketball fill nozzle.
Cut the gear lube cap so the hose is a tight fit and slide the hose so it reaches to the bottom of the bottle. poke a hole in the cap for the fill nozzle, fill the bottle with fluid, place the open end of the hose in the differential and slowly and add low air pressure and the fluid will be pushed up into the differential. Be careful and do not use too much pressure, the bottle can explode and not only make a mess but hurt you as well. I did use the soda bottle because it can hold more pressure than say just the gear lube bottle.
If I knew the exact amount needed to fill the differential I could have used a 2 liter bottle and added that amount and filled it with one shot.
TTFN
Mat
SSCARGO
Old Apr 19th, 09, 11:36 AM
yellow69RS's Avatar
yellow69RS yellow69RS is offline
Jeff
Default Re: Differential Gear Lube Filler
I use a suction gun. Pull the rod out , unscrew the top, fill with lube, screw top back on, insert hose into diff or trans, push rod in , repeat. looks exactly like this one.
http://www.plews.com/brochure.cfm?br...cation_id=2724
Jeff
Old Apr 19th, 09, 10:49 PM
Dale8346 Dale8346 is offline
Dale
Mat,
You can borrow my contraption anytime. I have been doing it this way for 35 years. Never spilled a drop.
Something wrong with this web page this evening. My picture is posted, but it is not showing up???????
You can also use something like Urethane, special caulking, lasts resort silicone to also CAULK the hose onto the bottle. Still use the clamp.
Then when this bottle is empty, put this lid on the next bottle.
67 R/S Coupe, Sierra Fawn
Old Apr 19th, 09, 10:51 PM
Dale
You guys were having problems with this web sight last night. No picture would post.
This 2nd post was an attempt to get the picture to show. Which it does today above.
Old Apr 20th, 09, 06:41 AM
Everett#2390's Avatar
Drive a '68!
Used to duct tape the lube bottle to the qtr panel and punch a hole in the bottom, gravity rules
Give a man a rescue dog for the health of his soul.
My 68 Camaro http://www.flickr.com/photos/everettwn68
Old Apr 20th, 09, 04:33 PM
Steptoe Steptoe is offline
Steps
By the time u guys mess around, head down to the local supply store pick up a suction gun and they are real cheap....shove the end into the oil bottle suck up the oil. poke in the diff hole and pump in.
Had a friend yrs ago, doing like u guys above squeezing the bottle etc...takes a while to squeeze and arms. wrist get a bit sore...i came home picked up my pump, cleaned it out, filled it and he was still putting his 1st bottle in....
His comment "you realy piss me off...how come you have all these wierd little tools and I dont" basically because I work hard at being lazy.
Old Apr 20th, 09, 08:35 PM
Dale
I just squirted the entire bottle above into my rear end.
It has been sittinng on the shelf since November.
Took 21 seconds. Not a drop spilled. I am not sure it can be done faster??
Old May 27th, 09, 12:28 PM
RSSSfanatic RSSSfanatic is offline
Tom
Dang - that must have hurt!
1967 RS/SS 350 Conv - triple black, 4sp, tach & gauges
1969 VN-built RS/SS 396 Conv - Garnet Red/Black, 4-sp, tach & gauges
