| Team Camaro Tech Current Topic: Pulley ? | ||
| Engine General Engine Discussion. |
I have a 67 that is setup 69 style alt on pass side long w/p.i'am about to add va a/c.What I want know,do I need a 2 groove w/p pulley,or does the comp run from the crank?Thanks
67ssclone 383 4spd 3.42 vintageair |
| Sponsored Links | ||
Advertisement | ||
carhodge, I expect you'll need a 2 groove wp as well as an additional crank pulley slot. I don't know where you'll mount the compressor - I'm in process of adding va a/c on my 67 short wp with alt on driver side. So, my comp goes on pass side above exhaust manifold - when I get the right mounting bracket - they sent one for headers.
Wilson 67 RS Convertible stock # matching 327/210 PG Original owner Full rotisserie restoration back on the road
FYI, my '69 was originally an a/c and power steering car. It has a three groove crank pulley and two grove water pump pulley. The a/c is long gone but I believe the belt ran around the crank and water pump like the alternator does.
Thanks,I have the 3 groove pulley,I added it when i added p/s.If anyone has pis I would appr.it.
| Sponsored Links | |
Advertisement | |
