3914638 is it a 307? - Team Camaro Tech
Thread Tools Display Modes
Old Apr 27th, 09, 05:07 PM
mark191 mark191 is offline
mark
Default 3914638 is it a 307?
Hi guys this is my first post on this site and I have to say that the info here has been very helpful! The problem I am having is the confusion over the casting number 3914638.The guy I bought it from swore it was a 68 327 truck motor but after tearing it down I found forged domes in it with the stamp std on the top which indicates standard bore.Well with the cylinders being in good shape i gave it a good honing job and got a set of 327 standard 4.00 pistons and they do not fit.Was wondering if anyone had this problem and if so what did you do.Thanks
Old Apr 27th, 09, 05:28 PM
dawg's Avatar
dawg dawg is online now
Harry
Default Re: 3914638 is it a 307?
thats a 307 cu inch motor
but you can bore to fit I assume
Dawgs 69
434 stroker
US Navy retired
http://www.northeastf-bodyassn.com/
Old Apr 27th, 09, 06:13 PM
mark
I dont understand how half the sites list it as a 327 and the others list it as a 307.
Old Apr 27th, 09, 06:58 PM
BillK BillK is offline
Mark,
My engine builders software and Mortec both show it as a 307. Which "site" says it is otherwise ??
Got to ask .... why would you buy a set of pistons without measuring the bore first ?
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
1971 Chevelle "Heavy Chevy" original owner
Enginerepairshop.com
Old Apr 27th, 09, 07:14 PM
mark
chevrolet car club is one site that lists it as a 327 2 bolt truck.And as for measuring the bore it was stupidity.But pretty sure i can just bore to size because the stroke is the same for 307 or 327
Old Apr 27th, 09, 07:39 PM
yellow69RS's Avatar
yellow69RS yellow69RS is offline
Jeff
I'm sure a machinist should be saying this but I wouldn't try to bore that block .125.
307 is 3.875 bore and 327 is 4.000
Jeff
Old Apr 28th, 09, 06:40 AM
dawg's Avatar
Harry
look for a suffix code on the block to find out if in fact its a 307 or 327 but you already tried a 4" piston and it didnt fit so you have a 307
Dawgs 69
434 stroker
US Navy retired
Old Apr 28th, 09, 05:39 PM
pdq67 pdq67 is offline
Banned
I'd sonic check it and bore away if it's OK..
pdq67
Old Apr 28th, 09, 07:24 PM
speedfreek speedfreek is offline
Patrick
Jeff
This is true! You must get new pistons.
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/8-7.6sec@88mph,1/4-12.1@110mph,Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
http://s90.photobucket.com/albums/k264/pnewell44/
Old Apr 28th, 09, 07:37 PM
GOSFAST GOSFAST is offline
Had a unit in here some time ago for a build, block #3914638. Most definitely a "stock" 327" (4.000" bore) core!
I do show a casting #3914636 as a 307"?
Thanks, Gary in N.Y.
P.S. Make certain the posted numbers are correct, some of these early casting's are difficult to read, especially while they're still somewhat dirty.
  #11
Old Apr 29th, 09, 04:53 PM
mark
pdq67
what is sonic checking? thanks
  #12
Old Apr 29th, 09, 05:49 PM
Banned
Smile Re: 3914638 is it a 307?
A sonic checking device is like a sonar gun that can measure part thicknesses once it's calibrated in.
You hold it's transducer, (i.e., sending head), tight against the part, (cylinder wall in this case ), a sonic wave goes out, returns and then it is converted electronically into thousandth's of inches or whatever...
A good Machine Shop should have one, imho.. It can tell you if the cylinders are thick enough before boring to bore an 1/8" over. As well as check for thinner rust spots and even sand cast pinholes and such.
The one I've seen is like the size of an old hand-held transistor radio w/ a transducer and cord on it. Nor much bigger than a dwell meter as I recall??
And if it won't bore an 1/8" over, heck, bore her a 1/16" over and turn her into a highly HOPPED UP 292 and go big engine hunting!!
pdq67
  #13
Old Apr 29th, 09, 06:11 PM
Vintage 68's Avatar
John
Wink Re: 3914638 is it a 307?
The confusion comes from the fact that GM used the 3914638 casting for some 307's - just underbored* it to 3.90"...
I've tore apart a 'DF' coded 307 a couple years back with a 638 block.
It is more common to find 307's using the 3914635 or 636 blocks though
As stated, bore it to fit your pistons you ordered and be done with it.
It will take a 4.0" bore, I've never run into a problem boring one to standard oversizes yet.
* = vs. a 4.0" bore for a 327 or 350 - don't start hate mail...
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
  #14
Old Apr 29th, 09, 06:52 PM
Banned
And I'm figuring most "round bottom" 283's will bore to .155" over just like a .030" 302" engine block!
BUT I would sonic check 1st!!
pdq67
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: 3914638 is it a 307?
Location
Location
First Name
Human Verification
