9" vs 8" vs 8" dual booster - Team Camaro Tech
Old Apr 28th, 09, 05:32 PM
Hood_Lum Hood_Lum is offline
Oliver
Default 9" vs 8" vs 8" dual booster
So the difference between a 8" and an 8" dual booster is roughly 20% from the searches I've done. Anyone know the difference between a 9"?
Is there a formula for this stuff?
67 Camaro
94 Miata
96 Camaro Z28
06 FX45
Old Apr 28th, 09, 05:45 PM
1stGenLvr 1stGenLvr is offline
Robert
Default Re: 9" vs 8" vs 8" dual booster
The 8" dual will provide slightly more assist then the 11" single, so it definitely provides much more than a 9". The "formula" is the square area of the diaphragms multiplied by the vac inches, so to speak, assuming the same vac it becomes a matter of calculating the surface area of the diaphragms for comparisons sake. A bigger booster is capable of more assist at a given vac, A 9" dual works very well, 11" dual(truck size) even better, however just doesn't look or fit as well as the 8" dual. Most that I know run the 8" dual with good success.
Back to your vac issue, 7-8"'s ain't going to cut it with ANY booster.
Old Apr 28th, 09, 05:55 PM
Skeeter55's Avatar
Skeeter55 Skeeter55 is offline
Skip
I have an 8" dual with 12" vacuum, i can tell that it recovers way faster then my 11" single did.
I NEED TO HIT THE LOTTERY
Old Apr 29th, 09, 11:32 AM
Oliver
I guess it's time to invest in a 8" dual.
My 13" vacuum and 7" booster ain't cutting it, that's for sure.
67 Camaro
94 Miata
96 Camaro Z28
06 FX45
Old Apr 29th, 09, 12:19 PM
Robert
You got your idle vac up to 13", that should work OK with the 8" dual. Not the greatest but should work.
Old Apr 29th, 09, 12:21 PM
Robert
While they both provide about the same assist with good vac, the 11" does seem to fall off quicker with low vac condition
Old Apr 29th, 09, 07:16 PM
ProdigyCustoms ProdigyCustoms is offline
Frank
We quite selling 7" single and Dual boosters, not enough umph! Our Polished Stainless 8" dual is out most popular. And as mentianed above recovers quickly.
Old Apr 29th, 09, 07:26 PM
Skeeter55's Avatar
Skip
I got this 8" dual diaphragm stainless steel from Frank Serafine ( ^ProdigyCustoms^) above and i am very happy with my purchase and hes customer service. I still need to order hes awesome master cylinder to match.
Old Apr 30th, 09, 12:03 AM
Oliver
Prodigy Customs doesnt have parts or prices online?
67 Camaro
94 Miata
96 Camaro Z28
06 FX45
Old Apr 30th, 09, 04:34 PM
chr2002ca chr2002ca is offline
Tech Team
Here's a chart that shows brake pressures for various booster and master cylinder sizes. Maybe it will be helpful:
http://www.classicperform.com/PDFs/B...ssureChart.pdf
-Chris
