Tools & Shops Shop Rat HQ
Old May 11th, 09, 11:25 PM
Shawn67RS Shawn67RS is offline
Tech Team
Shawn
Default Hot Water Pressure Washers
Wondering if anyone has a Hot Water Pressure Washer diesel or kerosene fired. Brand? Cost? Have to look for 115V. Completed the garage before the Camaro came so it's not wired (nor can be) for 220.
Old May 12th, 09, 11:04 AM
RJBaileyrn RJBaileyrn is offline
RJ
Default Re: Hot Water Pressure Washers
If you won't be using huge amounts of hot water, you might try what I did. My water heater is in my garage (Florida), so I plumbed in a hose bib right after the water heater so I can hook up a hose there and have hot water. Works great for me.
RJ
RJ Bailey
Vietnam Vet, 1st Air Cav
Lehigh Acres, FL
69 RS, 360, 4-speed, 9.7/1, 4.10, Comp XE274H, roller rockers, 195 alum. hds, Performer RPM intake, Quik Fuel 750dp, 1 5/8 headers, MSD 6AL & Pro-Billet Dist., Slide-a-links, TTII's, Nittos
Old May 12th, 09, 08:08 PM
ProdigyCustoms ProdigyCustoms is offline
Frank
I have a Hotsy 1000 PSI 190 degree pressure washer. It is 110V and only needs 4 gal per minute from a garden hose. Have not used it in years since it broke down. Was good while it lasted.
Frank Serafine
Prodigy Customs
Pro Touring Muscle Car Specialist
FREE PRO TOURING TECH and PROJECT PLANNING for Forum Members
Weekdays 8AM TO 10PM EASTERN TIME
FOUR ZERO SEVEN 832 1752
GP SuperStore
Group Purchase Discount Auto Parts
Old May 12th, 09, 11:42 PM
Tech Team
Shawn
Thanks Frank, I'll check into a Hotsy. Ive heard good things.
RJ, I like your suggestion but the wife might scream a little if I run a hose from the basement every weekend.
Old May 13th, 09, 08:01 AM
captcanuck68 captcanuck68 is offline
Ted
Had a bud back home who used a Karcher (steam type) with which he seemed pretty content. He used them for the clean up of trannys, eh?
capt
bumper sticker: Just say NO!...to negativity.
Old May 14th, 09, 05:41 AM
Frank
Steam is much different the high pressure hot water.
Makes me think, I should send that thing out for repair!
Frank Serafine
Prodigy Customs
GP SuperStore
