Where to get windshield channel metal?? - Team Camaro Tech
Body Shop Paint & Body Forum
Old May 12th, 09, 07:31 AM
68_RS 68_RS is offline
Default Where to get windshield channel metal??
I want to weld in some new metal for the windshield channel along the pillars and roof of my 68.
I've read that this needs to be fabbed up. Anyone done this that can point me in the right direction?
Old May 12th, 09, 07:55 AM
RealSS396 RealSS396 is offline
Default Re: Where to get windshield channel metal??
Eastwood used to sell 3/4 x 3/4 90 degree pre-bent strips of sheetmetal (L-shaped) with one side notched so you could form bends and contour it. I looked on their site & couldn't find it ... probably discontinued.
To create patchs, all you really need is the 18-20 gauge sheetmetal, a simple brake (vise) & tin snips for trimming & notching. As with any patch, you can create preliminary templates for test fitting using construction paper or poster board.
You can get fancy & get a shrinker/stretcher like Eastwoods to create complex bends.
http://www.eastwoodco.com/jump.jsp?i...rID=459&KICKER
Hope this helps ... Mark
Survivor '68 SS, #s matching, Ash Gold/Ivy Gold, black vinyl top, 396/325hp, TH400, factory A/C, PS, power disc/drum brakes
Pro Touring '70 Corvette, #s matching, Daytona Yellow/Black, convertible, 350/350hp with lots of goodies, Muncie 4-spd
Old May 12th, 09, 08:17 AM
thanks. too bad they discontinued that. Maybe I'll look for another source.
Old May 12th, 09, 09:08 AM
anyone else know where I could find something like that?
Old May 12th, 09, 09:28 AM
alanrw alanrw is offline
Alan
You could try calling a local sheet metal fabrication shop. If they have the steel, they can make it up in about 5 minutes. You can notch it with a 4" grinder and a cut off wheel.
alan
Old May 12th, 09, 11:35 AM
firstgenaddict firstgenaddict is offline
James
This area was in bad shape, I had to fabricate new metal and patch extensively.
Hand fabricated channel tig welded into place.
I fabricated these by first making a template with paperboard... (seen under the pieces) next I cut some sheet metal and bent a 90 deg bend to make and L shape the correct length. Finally I used a Eastwood Metal Shrinker to shrink the lower lip (where the glass would actually sit) by repeating the shrinking process the piece actually curves into shape...it only moves a small amount at a time so it is very easy to get right... just keep test fitting. The top one is finished ...the bottom one is about 1/2 way done.
James
"Collectin' Camaro's since only Rednecks Drove them"
https://picasaweb.google.com/1123922...28_Restoration
Old May 12th, 09, 01:07 PM
6781camaro's Avatar
6781camaro 6781camaro is offline
Todd
James
Nice metal work there!
'69 Frost Green V8 Coupe-Building now!
'68 Sequoia Green V8 Coupe--Building now!(too)
'68 6 cyl Coupe, '75 LT350, '79 Berlinetta V6, '79 Z/28, '80 Z28, '81 Z/28, '82 Berlinetta V8,'84 T-top V6, '89 RS V8, +finally a '92 Z/28 T-top in Purple Haze Metallic--...ALL SOLD
Helpful build pics+tips from my restoration:
http://s299.photobucket.com/albums/m...ro%20%20SS350/
My build thread:
http://www.camaros.net/forums/showthread.php?t=146455
Old May 12th, 09, 01:22 PM
Very nice.
Problem is that I'm not much of a fabricator. I was hoping to get a couple of those pre-notched 90 degree angles I could just weld into the pillars.
Are those being produced anywhere else?
Old May 12th, 09, 01:30 PM
GMJoe's Avatar
GMJoe GMJoe is offline
Joe
I've been looking at the strecher\shrinker for a while now, if it works well then it sounds like a good tool to have around the garage.
Old May 12th, 09, 08:19 PM
James
Thanks, I find alot of satisfaction in making something from scratch.
The Tig Welder was my Favorite addition... it makes the all the difference when fabricating sheetmetal.
James
Old May 12th, 09, 08:50 PM
Zulu28 Zulu28 is offline
Stephen
I would say that any body shop should be able to make that for you... Go to Home depot to get a sheet of 15-20 gauge steel take it to a shop, ask them to bend it and cut it... probably no more than $20 I would think...
"Schmidy"
I'm not sayin', I'm just sayin'
68 Camaro Pro-tour Project,
93 Wrangler w/ '07 5.3L (It's stupid fast)
11 Toyota Tundra Double Cab Off Road
08 CBR1000RR - The FAST bike
08 VTX1800F - The BIG bike
Old May 13th, 09, 08:39 AM
Icemans_67 Icemans_67 is offline
Don
You can get them here, http://autobodystore.net/Merchant2/m...egory_Code=MWH
Good Luck
Old May 13th, 09, 11:50 AM
That's it exactly!
I knew someone here would know.
Thanks for your help, man.
Old May 14th, 09, 10:30 PM
1320King 1320King is offline
Originally Posted by Icemans_67 View Post
But what do you do about the many openings in between the sliced metal?
Old May 15th, 09, 09:13 AM
Rhino Rhino is offline
Ryan
You have to weld them up. As such, that material may not be the best for a window channel.
I picked up a shrinker/stretcher at a local harbor freight for less than $100.
I purchased it to do a few window channel repairs, although I'm amazed at how much I've used it since.
