Hooking up a speedometer cable - Team Camaro Tech
Camaro Tech General Tech Area
Thread Tools Display Modes
Old May 15th, 09, 06:42 PM
Tbone1989 Tbone1989 is offline
Tech Team
Lamont Myers
Default Hooking up a speedometer cable
ok my buddy has a 1970 Camaro and the speedometer was not working so we figured out the problem. the cable was bad so my buddy went and bought a new one. when we tried to install the new cable it wouldnt plug into the back of the speedo. the ends on both the old/new cables are the same. the old one will plug right in the new one wont. we need help because we can not figure it out. SOMEONE PLEASE HELP!
Old May 15th, 09, 07:29 PM
Skeeter55's Avatar
Skeeter55 Skeeter55 is offline
Skip
Default Re: Hooking up a speedometer cable
Did you try twisting the inner cable at the other end as you were installing it to the speedo. Sometimes it takes a little twisting of the inner cable to line up and seat all the way in before you can tighten up the cable to the speedo.
I NEED TO HIT THE LOTTERY
Old May 15th, 09, 07:34 PM
Tech Team
Lamont Myers
well if i had to twist the inner cable on the new one wouldnt the old need the same thing i mean the new one will go on but not all the way.
Old May 15th, 09, 07:37 PM
Skeeter55's Avatar
Skip
Well it has to line up with the drive gear on both the trans and the speedo... Try to install the speedo first then the trans last.
Old May 15th, 09, 07:45 PM
Tech Team
Lamont Myers
it connects to the cruise contol box then to the trans...
Old May 15th, 09, 07:50 PM
Skeeter55's Avatar
Skip
If that cable looks like this then its the same cable as my 69 Camaro and yes do all the above to see if that works... Just my 2-cents.
http://cgi.ebay.com/67-68-69-70-71-7...3286.m20.l1116
Old May 15th, 09, 08:06 PM
Tech Team
Lamont Myers
ok thanks u are the MAN or WOMAN! WHICHEVER hehe idk but thanks i think that may fix the problem.
Old May 15th, 09, 08:44 PM
Skeeter55's Avatar
Skip
The MAN will work... I only wish i was the WOMAN....
Old May 15th, 09, 08:47 PM
Tech Team
Lamont Myers
Talking Re: Hooking up a speedometer cable
hahahahahaha thats funny thanks again for the tip could you add me so if i have any other questions because we are rebuilding this car piece by piece i can find you easier and im new to this site so i have no idea what im doin on here?
Old May 16th, 09, 07:29 AM
deerhunter deerhunter is offline
No need to add, now that you have found this site you can get all of the answers you will need. Welcome to the "wealth of information" site.
  #11
Old May 28th, 09, 11:08 PM
Tech Team
Lamont Myers
ok im still having problems hooking up the speedo on my buddys 77 camaro. the cable that runs from the speedo to the cruise control box is the the cabke im having troube with. it just will not plug into the back of the speedo. ive tried a members idea of twisting the inner cable but that didnt even come anywhere near working not that it was a not a good idea its just didnt work anybody else or skeeter have any ideas on how i can hook up the speedo. if i can i would rather not have to take outthe entire cluster gauge. please guys i am begging for ideas b/c ive tried everything i can think of and nothing is workin. PLEASE SOMEONE HELP i dont care if u think the idea is kinda moronic or if u think ive tried it before cause i may not have though of it.
  #12
Old May 29th, 09, 04:22 AM
Everett#2390's Avatar
<Jake-68's rule
Measure the square end in both x & y direction. The square crimp may be too big compared to the old cable end, or, the new end could be a rectangle.
Also, measure the open length of the cable to the old cable.
  #13
Old May 29th, 09, 08:04 AM
Have you checked to be sure there isn't a piece of the old one broke off in there?
  #14
Old May 29th, 09, 03:31 PM
Tech Team
Lamont Myers
actually i dont have a clue as to what any of that means but i know that both ends on the new and old cable are the exact same. and no i havent taken out the gauges to look at them im trying to hook up this cabe without having to do take out the gauges.
  #15
Old May 29th, 09, 03:39 PM
Tech Team
Lamont Myers
alsothe old cable was broken where it connects to the cruise control box and i dont how much was lost there.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Camaro Tech      Current Topic: Hooking up a speedometer cable
Location
Location
First Name
Human Verification
