Painting over original 1969 Lacquer paint? - Team Camaro Tech
Body Shop Paint & Body Forum
Thread Tools Display Modes
Old May 16th, 09, 11:08 PM
g356gear g356gear is offline
Default Painting over original 1969 Lacquer paint?
Hey guys,
I have a 69 Camaro that was painted 20 years ago with base/clear enamel over a lacquer paint job. The entire car was shot with a primer sealer before the enamel was layed down but now there is an issue. As the car has been sitting so long, over time, there are several spots where the paint has lifted making it look like many smalll bubbles under the paint. Obviously the car needs to be painted again but what would be the recommendations for the new paint? Take it down to the original factory lacquer and then what?
Old May 16th, 09, 11:21 PM
67CAMAROSS 67CAMAROSS is offline
DONNIE
Default Re: Painting over original 1969 Lacquer paint?
all the way down to the medal strip the whole thing
"Well, the trouble with our liberal friends is not that they are ignorant, but that they know so much that isn't so." -- Ronald Reagan
http://s274.photobucket.com/albums/j...HEROCK1_photo/
Old May 16th, 09, 11:36 PM
The car was painted once back in the late 70's and the color of the car was changed at that point. Problem is that the car had a ton of hours of body work getting it laser straight with that paint job. I think that is why it wasn't taken down when it was refreshed in 89, just sanded down, primed and re-shot. Taking it down to the metal is not really an option for me.
I do however want to change back to the original color.
Old May 16th, 09, 11:50 PM
DONNIE
the new b/c paints dont work well with the old stuff makes it pull up and fish eye. they attack each other
Old May 17th, 09, 01:25 AM
rs69ss rs69ss is offline
ED
you sure 20 years ago it was base/clear enamel and not urethane? I would have thought the enamel would have held up without material conflict's at least. Maybe these bubbles are a metal rust concern or moisture getting in any body filler under paint. Changing color again will be a large job because you will need to disassemble body just to get good adhesion in the jams. If this is a keeper nows the time to strip it. I liked the old base/clear PPG because they had a activator for the base too and i have seen cars that had problems later with out it. Dupont says you can use their chromapremier hardener in their base. Also too much paint, filler and sealer causes problems. Material mills should be kept at minimum
Old May 17th, 09, 06:31 AM
Barefoot Dave's Avatar
Barefoot Dave Barefoot Dave is offline
Dave
I hate to say it but if you want to do it right...and only have to do it once...it needs to become the ONLY option. That way you'll know exactly what you have to begin with and won't be covering up mistakes and problems from 20 years ago.
1969 Camaro Z-10
2011 Camaro 2SS
Old May 17th, 09, 10:57 AM
Original68fromauntsgarage Original68fromauntsgarage is offline
Don
BARE METAL. Period;
Trust me I too feel the "pain" of that statement, but I am in the same boat. I took mine all the way down; I very glad I did too. It should be shot in about a month or two, but I am very satisfied knowing I am not taking any chances.......
Why put in GOBS of time and very hard work to "hope" it all goes alright?
Just put in the time and go to bare metal. If you have to do a bit of body work, so be it.......it will be fresh.....
Good luck.
My 68 coupe that I begged for since age 6..350, 4 speed, new paint
See some progress below!
http://i13.photobucket.com/albums/a2...t/IMG_0977.jpg
http://i13.photobucket.com/albums/a2...IMG_1648-1.jpg
Old May 17th, 09, 11:49 AM
69Z28-RS 69Z28-RS is offline
Gary
I'd guess the problem was with the enamel that was shot in the '70's.. it was common at that time to use either 'straight enamel', or acrylic enamel, and then clear over it. but to answer the original poster's question, if the *factory lacquer' is in good shape, no checking, cracking, etc... then almost anything can be painted over it without problems, but it's a good idea to seal it in with an epoxy primer. If that is done, I wouldn't tihnk it would be an issue to leave 'spots' of factory primer or lacquer.. just block sand down til all the enamel and any other bad paint is gone, and use epoxy over it... then do the new primer/paint...
Gary
69Z28-RS
Corvettes (5), Nomads (2), El Camino, etc
Old May 17th, 09, 11:52 AM
I know in my heart that's probably the best way to go. Any recommendations for the new type of paint?
What's the best way to get this thing stripped? Chemical? Sanding?
The undercarriage, interior, and engine compartment are already finished and fully detailed.
Old May 17th, 09, 11:56 AM
The paint that was shot in the 70's, I am sure was lacquer again. When it was reshot in 89, the 70's paint was badly checked and cracked on the roof, fenders, trunk, etc. It was was sanded down to minimize the cracked paint and then shot with a primer filler before being painted with the base/clear enamel that us currently on the car.
  #11
Old May 17th, 09, 01:24 PM
Gary
If you use a chemical stripper on the paint, then you'd better remove ALL the paint, down to metal, and then make sure it's neutralized totally...... and then wipe down with lacquer thinner on the bare metal, before you apply anything new
Gary
69Z28-RS
  #12
Old May 17th, 09, 04:45 PM
firstgenaddict firstgenaddict is offline
James
If you dont want to have to totally disassemble it then have it soda blasted...
James
"Collectin' Camaro's since only Rednecks Drove them"
https://picasaweb.google.com/1123922...28_Restoration
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Body Shop      Current Topic: Painting over original 1969 Lacquer paint?
Location
Location
First Name
Human Verification
