Tools & Shops Shop Rat HQ
Old May 20th, 09, 05:54 AM
schnide schnide is offline
Mike
Default IR compressor filter restriction
I bought a 3hp 60gal IR compressor from Tractor Supply, and was very disappionted with it. It would not keep up with any air tools, even ones that were 1/4 the cfm rating of the compressor.
One day while checking the filter I noticed that the plastic housing that threads into the comp head had very small openings, in fact some were almost shut with material left from the molding die. I cut these openings out as large as I could with my trusty pocket knife and it made a huge difference!
I called IR to make them aware of this and they acted like they didn't even care.
Just thought I'd share...
Schnide
Old May 20th, 09, 10:15 PM
69 merlinpro565 69 merlinpro565 is offline
Big Dave
Default Re: IR compressor filter restriction
Glad you found the problem...
My friend had a similar problem with his compressor.
He had some casting that was blocking the intake.
You gotta figure if it can't suck...it can't blow!
'69 camaro, was orig SS 396 car.
original tranny & 12 bolt
Now: 565 ci, Nash 5 speed, 9'' Ford.
