| Team Camaro Tech Current Topic: Quarter Panel Stiffener Braces | ||
| Body Shop Paint & Body Forum |
I need to install a set of quarter panel stiffener braces. Does anyone have any good pictures of how they are mounted? I have not been able to find any.
67 Camaro Coupe |
| Sponsored Links | ||
Advertisement | ||
I have a few shots of them in my thread I know. They are simply spot-welded onto the front-facing surface of the sail panel window channel and then spot-welded three times onto each quarter panel. I will try to get you the post # in a second. Here are pics of mine when installed still.... ![]() ![]() ![]() OR--- Did you mean these?:
'69 Frost Green V8 Coupe-Building now! '68 Sequoia Green V8 Coupe--Building now!(too) ![]() '68 6 cyl Coupe, '75 LT350, '79 Berlinetta V6, '79 Z/28, '80 Z28, '81 Z/28, '82 Berlinetta V8,'84 T-top V6, '89 RS V8, +finally a '92 Z/28 T-top in Purple Haze Metallic--...ALL SOLD ![]() Helpful build pics+tips from my restoration: http://s299.photobucket.com/albums/m...ro%20%20SS350/ My build thread: http://www.camaros.net/forums/showthread.php?t=146455 Last edited by 6781camaro; May 21st, 09 at 01:05 PM. |
The bottom picture is the drivers side qtr panel stiffeners. For reference in the picture above, the raised part you see in the shot goes at the front corner of the trunk surround on the qtr panel. In the picture it is upside down. The one pictured on the left would be on the driver side. The area with the hole is spot welded to the trunk lip area and the other part of it is glued to the qtr |
Thanks guys!
The first shots with the braces near the window is what I need . The stiffeners at the trunk opening I have covered. Great Pictures, by the way.
67 Camaro Coupe |
Anytime I can help out! I have over 800 pics that I am willing to share... Just ask.
'69 Frost Green V8 Coupe-Building now! '68 Sequoia Green V8 Coupe--Building now!(too) ![]() '68 6 cyl Coupe, '75 LT350, '79 Berlinetta V6, '79 Z/28, '80 Z28, '81 Z/28, '82 Berlinetta V8,'84 T-top V6, '89 RS V8, +finally a '92 Z/28 T-top in Purple Haze Metallic--...ALL SOLD ![]() Helpful build pics+tips from my restoration: http://s299.photobucket.com/albums/m...ro%20%20SS350/ My build thread: http://www.camaros.net/forums/showthread.php?t=146455 |
| Sponsored Links | |
Advertisement | |
