Rusted Subframe Repair - Team Camaro Tech
Body Shop Paint & Body Forum
Thread Tools Display Modes
Old May 22nd, 09, 12:38 AM
69z28freak's Avatar
69z28freak 69z28freak is offline
Mike
Default Rusted Subframe Repair
Does anyone have any advise to repair the subframe connector brackets that are rusted out? Can I get new brackets or can I repair the rusted out ones. My concern is doing the repair and not affecting alignment. Or should I get a new subframe. If a new subframe is the way to go, I would prefer an original one as I am not a fan of non original. Are original ones available? I had no idea mine was rusted out until I removed it from the car. Sound familiar?
Grandma, 69.5, Z/28 Finally Done! Well almost...
My Build Thread
http://www.camaros.net/forums/showth...ght=69+grandma
BC Camaro Club
http://www.bccamaroclub.com/#!builds/c8ky
The Rod & Custom Shop
http://www.therodandcustomshop.com/
Old May 22nd, 09, 02:25 AM
buenymayor buenymayor is offline
Default Re: Rusted Subframe Repair
If you are talking about the body mount holes, yes, there are repair kits from the Camaro vendors. Getting a different sub frame is an option, too. They are out there.
Experience...... It's what you get when you didn't get what you wanted.
Old May 22nd, 09, 08:32 AM
DHH's Avatar
DHH DHH is offline
Don
I had one mount that was rusted out. I bought the repair plates that have the hole pre cut and a buddy and I had it welded in in about 20 minutes. Nobody will ever see it, worked like a charm.
Some videos I'v made for youtube
http://www.youtube.com/user/dons69camaro
Old May 22nd, 09, 03:44 PM
Moonpie's Avatar
Moonpie Moonpie is offline
Mickey
If the 5/8 alignment hole is still visible in any of the rusted pieces be sure and use it to align the new plates to. Two ways to repair-put the new plates on top of the old ones and weld or cut the old ones out and weld in the new. I ran into the same problem with mine.
Old May 22nd, 09, 06:54 PM
Zulu28 Zulu28 is offline
Team Member
Stephen
I had the local waterjet place cut me some patches out of 1/8" thick steel I think that I had them made with the inside diameter at 1.5" and the outside ones at 2-3/4" (not too sure about the outside measurements but I don't think it really matters) If I were to do it again, I would cut the inside holes at like 1.60" or something. They were just not big enough at the size they were cut at and that extra 0.1" would be enough to allow the bushing to slip in there.
"Schmidy"
I'm not sayin', I'm just sayin'
68 Camaro Pro-tour Project,
93 Wrangler w/ '07 5.3L (It's stupid fast)
11 Toyota Tundra Double Cab Off Road
08 CBR1000RR - The FAST bike
08 VTX1800F - The BIG bike
Old May 23rd, 09, 12:06 AM
69z28freak's Avatar
Mike
Does anybody have a picture just so I don't screw it up. I don't want the holes to be off so my alignment would be affected. Thanks
My Build Thread
BC Camaro Club
Old May 23rd, 09, 07:04 AM
Team Member
Stephen
I think the measurements are what you need more what you need than pics... the location of the center of the hole wold be the most impoortant thing that you need to pay attention to.
"Schmidy"
Old May 24th, 09, 01:14 PM
69z28freak's Avatar
Mike
Here are a few pictures of the subframe. The drivers side is squished where the bushing goes. What is the best way to repair it. Thanks
My Build Thread
BC Camaro Club
Old May 24th, 09, 11:22 PM
Team Member
Stephen
Um, yeah... That thing is JACKED!!!! Good luck!!!
"Schmidy"
Old May 24th, 09, 11:45 PM
69z28freak's Avatar
Mike
Hey Zulu do you suggest I find another sub frame or repair? I don't want to waste time on a basket case. I knew I was in trouble when the frame slipped over the bushings. The deeper I dig the more I think this project wants to just be allowed to die peacefully. Seems like a shame, but there is a point when a humanitarian decission must be made. Should I euthanise?
My Build Thread
BC Camaro Club
  #11
Old May 25th, 09, 05:27 AM
6781camaro's Avatar
6781camaro 6781camaro is offline
Todd
If that's all that's damaged, it's fixable. For the squeezed in section, you can use a hydraulic port-o-power unit to open it back up, OR you can simply cut that section out just on that surface and weld in a thick plate that replaces it.
For the firewall subframe mount perch that is rotted away, you can buy a patch kit for those. It is $52 for the kit in most catalogs and easy to weld in place. I would print out the Fisher body specs measurement sheet for your car, and go from there.
You may want to strip down those areas further with a wire brush to see just how far the "rot" exists. JMHO....
Here's the link to the kit:
http://www.rickscamaros.com/product....5&dept_id=3513
'69 Frost Green V8 Coupe-Building now!
'68 Sequoia Green V8 Coupe--Building now!(too)
'68 6 cyl Coupe, '75 LT350, '79 Berlinetta V6, '79 Z/28, '80 Z28, '81 Z/28, '82 Berlinetta V8,'84 T-top V6, '89 RS V8, +finally a '92 Z/28 T-top in Purple Haze Metallic--...ALL SOLD
Helpful build pics+tips from my restoration:
http://s299.photobucket.com/albums/m...ro%20%20SS350/
My build thread:
http://www.camaros.net/forums/showthread.php?t=146455
  #12
Old May 25th, 09, 06:24 AM
amartinson amartinson is offline
Andy
I think your plan "A" should be to try to find a reasonably priced rust free replacement subframe. Plan "B" should be to repair what you have IMO.
  #13
Old May 25th, 09, 08:24 PM
hiltman hiltman is offline
Tech Team
John
Where can we get this information from? Any links? Thanks,
John
  #14
Old May 25th, 09, 08:51 PM
69z28freak's Avatar
Mike
Hey John here are the specs that Scott sent me.
My Build Thread
BC Camaro Club
  #15
Old May 25th, 09, 08:52 PM
69z28freak's Avatar
Mike
Hey Andy any idea where I can find an original subframe in good shape? I have never seen one, but would love to go that option if possible.
My Build Thread
BC Camaro Club
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Body Shop      Current Topic: Rusted Subframe Repair
Location
Location
First Name
Human Verification
