| Team Camaro Tech Current Topic: Getting RWL's White Again | ||
Wheels & Tires What fits what?
Does anyone have any secrets as to how to get the Raised White Lettering on your tires looking like new? I have Goodrich Radial T/A's and they are getting dingy from the tire protectant being applied. My car sits in the garage until cruise nights. I have tried Bleach White, and SOS pads. They look better but not how I would like them to look. Thanks!
| Sponsored Links | ||
Advertisement | ||
white out!!!
permanent but if u mess up, u can always rub away, cheap and also good for precision, either pen or brush..
Vic 1969 Camaro SS |
Hands down the least expensive, works best solution is an SOS pad from under the kitchen sink. I learned from my dad and they were using SOS before his time! A little water then scrub the entire side wall of the tire and hose off.
Spray it on dry- scrub the tire with a wet brush- rinse with hose. (Biodegradable.) Make sure you rinse the dirt off the driveway, after you wash your tire. ( the black dirt from your tire will stain the concrete it if it dries) |
enamel reducer is what I used to use when I had RWT's ( a little on a rag )
________________________________ 1969 Camaro BBC Coupe / 468ci / th400 / 12bolt posi - 3:73's / Black with Red Int. http://s923.photobucket.com/user/dby...20Coupe?sort=3 Last edited by ddx77; Jun 7th, 09 at 05:33 PM. Reason: sp |
http://www.westleys.com/
makes the black blacker as well |
The key I have found to keeping white letters looking white after you have scrubbed the heck out of them. Before you apply the tire dressing. Get a clean cloth towel and apply the dressing to the white letters first and only the white letters. Then come back with another towel and apply the tire dressing to the rest of the tire. Other wise when you do them together the black tire rubs onto the white letters some making them get dingy looking quicker.
-Just my 2 cents. -Doug |
Thanks for all the ideas! Ed
I tried everything and imho, 'nuthin worked... Now I lightly wet sand them with 240 and with my finger as the pad.
'67 RS/SS 350 |
Laquer Thinner here on a rag,think we are crazy try it and you wont ever try anything else ever again.
1969 Camaro Convertible 427 5 Speed |
#11
Black walls
#12
Simple Green & a scrub brush works really well.
#13
![]() I have not run RWL tires in a long time though, black walls for me now and that definitely takes care of the problem.
Sean 1968rs, formerly a 406 sbc, 354" SB2.2 coming soon... "Aerodynamics is for people who don't know how to build engines" - Enzo Ferrari |
#14
Apparently Dennish knows his stuff when it comes to cleaning raised white lettering on tires as I used to use these too however I refer to them as Brillo pads which are steel wool soap pads!....They work excellent!
#15
I used these to clean the letters as well. Works great. Looks like allot of us use them.
| Sponsored Links | |
Advertisement | |
