| Team Camaro Tech Current Topic: Can i put a hitch on my 94 v6? | ||
| Camaro Tech General Tech Area For best results use specific forums |
I own a 94 v6 camaro and am moving my small 300 suzuki GS300L down to florida from indiana and DO NOT want my parents help. My camaro came with a hitch but my father took it off saying my car didnt have the power. Could I put one on and be able to tow an small open trailor down?
HELP |
| Sponsored Links | ||
Advertisement | ||
I used to tow a large 3 passenger Yamaha Waverunner on a single trailer back when I had my 1993 with the 3.4 litre v-6 and 5 speed manual..
I had no problems towing it, even going up long mountain passes... |
Sure you can. Check your owner's manual for towing capacity. Towing capacity is as much a function of suspension components as it is powertrain components.
Here is a Class I hitch (1000 lb. max). You can probably stop by any auto parts store and have them look up a hitch for your car. There will not be one made specifically for your application that is sized larger than your car's towing capacity. http://www.autoanything.com/towing/7...0A2587708.aspx The Reese part number for the plug-in trailer wiring harness is R3474051. You just separate a specific tail light plug and insert the wiring harness and you've got a trailer hookup.
'69 Camaro X11 Street Car Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III TKO-600 - Moser 3.42 - Detroit Truetrac 538 lb-ft - 500 hp www.cmengines.com '69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10 '02 Z/28 vert - stock |
| Sponsored Links | |
Advertisement | |
