| Team Camaro Tech Current Topic: Modern Pro-Street??? | ||
Lateral-g has a modern Pro-Street section how do you all like the modern look.I am kind of the fifteen inch wheel kind of guy but the tall deep look is kind of growing on me.It may grow on me but dont think I will make the change because of the cost.Post some of your modern PS cars if you got um.....
I love the look your just so limited in wheel choices dew to there is only a few companys making the big rollers in 15" wide not to mention the amount of jack it cost per wheel called budnik the other day to see if they would make me a set of just 15x15's and they said they had to cut down two 10" wide hoops and weld them together and true them up the 15"s were 780.00 a wheel a 20 is over 1k a wheel. Mickey thmpson has about the only nice choice but there up there in money aswell
1948 Chevrolet Fleetline Areosedan PRO STREET! 406 Solid Roller motor! |
I personally hate that look. What purpose does it serve? I saw a high dollar "$240K" 70 Camaro at a show the car was built t the T it was a show only car with a "modern" Pro Street look. The rear wheels totally took away from the car. The rear brakeks looked tiny and the Chevy bolt pattern looked silly on a 5 spoke wheel of that size. It had to be 22-24" wheel. I will see it I can find a picture of it.
The only thing pro street about them is that they won't perorf at the track. The sidewall is far to short and stiff to ever hook up. So these cars are nothing more than posers. At least "real" pro street cars have the correct equipment to perform even if many never see a track. You can at least look at them and know they mean business. The true meaning of a Pro Street car is it's supposed to look like a drag car, except have treaded tires instead on slicks for street use. How many Pro Stock cars do you see with 20"+ wheels? Don't you think if there were an advantage they would be using them. I'll just be glad when the "clown shoe" (big wheel) fad passes. The only thing they look decent on are trucks/SUV's and a few modern cars that the wheel openings were designed for the larger wheels (think Dodge/Chrysler 300M). Of course the above is just my honest openion, take it for what it's worth. You will never see those big wheel on any classic car I own PERIOD.
Royce (NO XQSSS) Bradley Pictures Sound Clip (brief sound clip, 3" exhaust through Borla Sportsman mufflers) "If you are not part of the solution, then you are part of the problem" Me |
![]() .![]() David F.
"All I need is a fast machine". Steve McQueen My Machine: 1969 Pro Street Camaro ![]() 468 CID 648 Horsepower Turbo 40033"x19.50" Mickey Thompsons Check Out My Pro Street Camaro 648 Horsepower 468 |
Whos is this David looks like we need some more pics of this one....
David F.
I am with Royce and David here.I do like a little rake in a pro street though..and the above picture ^ is a great example of that.
George 68 Camaro 8-71 blown 461 Rat |
Yes, that is Pro Street. Maybe we can come up with a new name for the "Modern" Pro Street, something that doesn't have "Pro Street" in the name.
I thought modern pro-street meant you had a dual needle seat blow through carb.
![]() Just kidding. |
Here is my meaning of "Pro street"....
Sean 1968 rs, 406 CI "mouse". If it's not heads-up, it's not drag racing.... |
#11
#12
looks good, not very usable though!!
#13
I feel the same way you guys feel. I like the big meats in the back. I bought a set of the MT SR Radials and did not like them. They were 33 x 22 x 15 too. They were great for the street but if you hit them hard or even at a roll thay acted real funny. It was kinda scary. I put the Hoosier Quick Time Pros back on it and now the car acts normal again.
Mike 69 Camaro Prostreet - purple w/ghost flames , 502 w/ 871 blower http://s268.photobucket.com/albums/j...treet69camaro/ |
#14
I am pretty much in agreement.
To me Pro-street is a street (some would say questionable) drivable drag car. Huge meats, usually drag radials, cage, monster engine, back halved etc The "Modern" pro-street cars (and I know this is a bad generalisation) are mostly PT cars with huge rear tyres. That is they are LSx/T56 based, usually no cage (not always but usually), not really designed for drag strip use. Here is an example (not my car) ![]() Now this will sound wierd, but I like both styles yet don't consider my car to be either. It is not PS and it is not PT, but it is inbetween 4 Link rear 11" Rims 324 x 45 series M&H Drag Radial 632 BBC (crate motor at this stage, will be blown later) TH400 9" rear with 35 spline with a Detriot locker AME Front clip 330mm discs allround coilovers all round 17" rims all round Car still very much in build stage (here is a pic) ![]() I agree we need a better name for mostly PT based cars that have massive rear wheels. Having said that I have seen some outstanding PS car that run 20's. Is it practical down the strip and do they drag em with the 20's? No they usually swap em for a tyre with a larger sidewall. The 20's and rubber bands are for looks on the street. Last edited by cluxford; Jun 16th, 09 at 05:52 PM. |
#15
i call them "Pro Hot Wheels".
you don't plan sincerity. you have to make it up on the spot. my 1974 Monte Carlo & 84 Turbo Buick 86 Monte SS that should probably be crushed |
