| Team Camaro Tech Current Topic: Big block worth | ||
| What's it worth? & ebay discussions |
I found a bare block with a cast no. 3969854.. Nothing else included.. I think I can get it for 200.. Is that a good price, or could I find a better deal on a complete engine... Thanks
| Sponsored Links | ||
Advertisement | ||
Build her fat!!! Any good block is worth 200.00....
854 blocks,late 1969 blocks,came 2 and 4 bolt.$200.00 bucks is a steal !! Buy it,build it,enjoy it!!
I just picked it up.. 150 bucks.. It looks pretty good too.. It has A 23 70 on the front.. It Has a K on it also, as well as some other numbers... As you can tell I don't know much about these things, but I am wanting to have it rebuilt and put it in my 69... How will I know if it was a 396 or a 402?? Also, I was told that it could be a truck engine, how can I tell?? It says Hi perf Pass also.. Thanks in advance...
3969854....402.......70-72...2 or 4 bolt 3999290....402.......70-72...2 or 4 bolt, Truck I'm not so sure that the block is a 396 but here are casting #'s for identification. Note that none of them list 1970 as a production year though...... 3969854....396.......69......2 or 4 bolt 3999290....396.......68-69...2 or 4 bolt, Truck 3916323....396.......68......2 or 4 bolt 3902406....396.......67......2 or 4 bolt 3855962....396.......65-66...4-bolt 3855961....396.......65-66...2 or 4 bolt David F.
"All I need is a fast machine". Steve McQueen My Machine: 1969 Pro Street Camaro ![]() 468 CID 661 Horsepower Turbo 40033"x19.50" Mickey Thompsons Check Out My Camaro 661 Horsepower 468 |
4.094" diameter bore is standard bore for a 396. 4.125" diameter bore is .030" overbore for a 396 and is also the standard bore size for a 402.
67 Camaro: 454/TH400/4.10 12 bolt. Lots of options: PS/PDB/PW, tilt, tach, gauges and more. K-K + 797Z..... |
If the assembly stamping is still on the pad in front of the passenger head, it would tell you what it was. Stamp should be Txxxxyy where the xxxx are numbers and the yy are letters (if it is a 70 up model, it would be TxxxxCyy or TxxxxTyy). A partial VIN (probably on the vertical flange above the oil filter) would tell you what it was originally installed in.
In this case, even if it went in a truck, it doesn't matter. Some truck engines (in the heavier duty trucks) are "tall deck" blocks, and that is a problem. The block you bought is not a tall deck, so even if it was originally installed in a light duty truck, it is the same as a car.
Eric 69 'vert project big block/TKO 600 RR 68 'vert driver RS clone -- gone! |
Thank you for the information.. I am unable to find the numbers you are referring to. Im sure that the block had been surfaced at some point.. I have no idea where to start looking for a decent set of heads and a crank.. That will be my next challenge...
| Sponsored Links | |
Advertisement | |
