| Team Camaro Tech Current Topic: 1969 Camaro Brake issues | ||
| Brakes, Suspension & Steering Conversion questions, Steering & Handling |
Hello-
I just replaced my Master Cylinder-Brake Booster-Brake Lines-Metering Block-and Proportioning Valve-My brake pedal is stuck in the up position and wont move at all? I attached the Clevis to the lower hole of the brake pedal, for power brakes. I also bench bled the Master Cylinder. Im lost Please Help Charles |
| Sponsored Links | ||
Advertisement | ||
Did something wrong, back up think and try again, probally missed the rod into M/C?
I pulled the MC from booster and the pedal moves.
the MC rod appears to be too long? Is that possible? what length should the rod be? |
Measure it...
Did the car have power brakes before?
check out this tread: what exactly seals the power brake booster to the master cylinder? |
Car had power brakes before-front disc and rear drum-booster and MC-no proportioning valve or metering block though
push rod was replaced with the smaller one and the brakes engage now-Thank you
How many times do I have to bleed the brakes in order for them to feel right? I have to push hard on the brake pedal-before it was effortless, just doesnt feel right. any ideas? |
| Sponsored Links | |
Advertisement | |
